243 user(s) are online (120 user(s) are browsing Forums)
EngineDoctor 504 HP 383 Ingredients
La Habra Ca.
791 Posts
Just Dyno'd , but darn we wanted 520+ HP. Maybe after a few adjustment we'll get there , anyhow she has:
Scat rotating assembly with 5.7 rods
Probe flat top pistons
Brodix heads
Solid Custom Cam (secret)
9:1 comppression
Blueprinted & Balanced.
I think after playing with the valve adjustment we'll hit our mark. Gonna close up the clearance.
jpg  385010_2026472680059_1791312576_1418555_213180068_n.jpg (19.69 KB)
7794_4f40310045916.jpg 240X320 px
Posted on: 2012/2/18 23:15
Matatk Re: 504 HP 383 Ingredients
22947 Posts
Sounds pretty stout. What is the torque and what did it peak at, how did the power curve look?
Is that a pretty big solid cam? How does it idle, what will street manners be?
Posted on: 2012/2/19 0:03
EngineDoctor Re: 504 HP 383 Ingredients
La Habra Ca.
791 Posts
I'll post numbers at a later time.
Right now we are resetting the valve lash from int@.026/ex@.030 to int.@ .018/ex@ .021 & bumping up the ign. timing to to see wat we get.
Posted on: 2012/2/19 0:43
La Habra Ca.
791 Posts
Final numbers...
518 HP/438.1 Torque @ 6,200 RPM.
I'm leaving it there , close enough.
Gotta run 2200 stall converter
Medium idle, fender rocker
Maybe a carb swap now... we'll see??
Posted on: 2012/2/19 3:23
22947 Posts
Impressive!
Posted on: 2012/2/19 3:39
La Habra Ca.
791 Posts
I gave Andy a Blue Print form that I use to help obtain these results.
He/ You are welcome to use this to assist in a bit better engine build . I am sure that form can be improved upon too.
Posted on: 2012/2/19 4:07
Durango_Boy Re: 504 HP 383 Ingredients
Question - Why the 9.0:1 SCR? That is a very stout rotating assembly and even a .25 to .75 bump in compression would net huge gains with what I assume to be a very versatile cam profile.
Posted on: 2012/2/19 4:50
La Habra Ca.
791 Posts
9:1 @ customer request.
Posted on: 2012/2/19 6:22
La Habra Ca.
791 Posts
His plan was to build a reliable low compression short block, then play with different cc heads & different gasket later.
Posted on: 2012/2/20 1:52
It's a good plan for sure, and quite amazing that the goals were reached with it. As long as that's what he wanted and he's happy with his results. I wonder though, since HP is a disease, if he'll kick himself later for not building a 9.50:1 or 9.75:1...which would give him the ability to reach to higher goals.
Posted on: 2012/2/20 22:11
bogus Re: 504 HP 383 Ingredients
20878 Posts
I have gone over your build sheet... I will be honest, if there is a need to improve, I don't see it.
Any more info would just get to being too much, and the numbers you ARE recording seem to be the ones that matter the most.
Short of recording head specs into the document... but this is a build sheet, not a spec sheet.
Posted on: 2012/2/21 2:53
La Habra Ca.
791 Posts
Customer mentioned nitrous ....He's happy.
Posted on: 2012/2/21 3:06
bearcat Re: 504 HP 383 Ingredients
West Texas
20 Posts
That is a very impress level of power for a 9:1 compression motor! Very good work.
There was some mention of compression ratio, having huge gains to a bump of half a point in compression or so. There would be some gains, but I don't think it would be huge. And I think you could get that with just a swap to a steel shim head gasket probably.
I think being able to obtain that horsepower goal without having to buy the expensive gas is a very good idea. Good job!
Posted on: 2013/3/10 17:20
'68 427 Shark
'68 455 Firebird
'52 GMC pickup
'88 C4 Corvette
La Habra Ca.
791 Posts
Thanks Bearcat! He has not changed a thing on it. He remains content the way it is, except for the nitrous ;)
Posted on: 2013/3/10 20:14
