603 user(s) are online (76 user(s) are browsing Forums)
FICINJECTORS Injector Videos!!
Gold Sponsor Vendor
117 Posts
WE RECEIVE SO MANY E MAILS REQUESTING WHERE THESE VIDEOS ARE SO I DECIDED TO PUT THEM ALL ON ONE THREAD.
SPRAY PATTERN COMPARED ON 6 POPULAR INJECTORS USED IN CORVETTES
INJECTOR LEAKDOWN RATE
TYPICAL MULTEC FAILURE
MORE BAD MULTECS (COMMON PROBLEM)
HOW TO OHM CHECK YOU INJECTORS
FLOW MATCHED BOSCH III FOR CORVETTE
85-88 STOCK BOSCH COMPARED TO THE DESIGN III BOSCH
EARLY BOSCH DESIGN II COMPARED TO DESIGN III BOSCH
LUCAS DISC VS BOSCH (BOTH NEW 30’S SPRAY PATTEN DIFFERENCE)
STOCK MULTEC COMPARED TO LUCAS DISC AND TO BOSCH DESIGN III 22lb
STOCK LT1 24lb compared to BOSCH III 24 LB
FUEL INJECTOR IN SLOW MOTION
CUSTOM INJECTOR SIZING FOR PERFORMANCE ENGINES
FOR CROSSFIRE 84'S ONLY
Posted on: 2011/5/3 14:17
FICINJECTORS Re: Injector Videos!!
Gold Sponsor Vendor
117 Posts
re-did all the videos to embed them into the thread.
Enjoy!!!
Posted on: 2011/5/13 18:24
TommyT-Bone Re: Injector Videos!!
34655 Posts
Nice.
Posted on: 2011/5/13 21:42
Gold Sponsor Vendor
117 Posts
Thanks Tommy! Hope they help everyone since the sticky was pulled on the other site.
Posted on: 2011/5/16 3:27
istter1 Re: Injector Videos!!
Bakersfield Ca
2336 Posts
Learned a lot
Posted on: 2011/7/11 3:52
Schrade Re: Injector Videos!!
Why did they pull the stickies???
That was MY idea - posting them in one C4TechPerf thread, and getting them stickied. I suggested to you to do that in a PM over there '07, (user Schrade, before banned), and to Jim and Jessie, and they said no, since you weren't a vendor at the time. Told them it would generate hit$ / ad revenue.
'Tards. http://www.garagejournal.com/forum/images/smilies/tard.gif :rolleyes:
They can do the hermaphroditic thing, as far as I'm concerned... (and as DurangoBoy noted, they've got a start on the procedure)
Durango_Boy wrote:
Because they have heads firmly positioned up asses.
(hermaphrodites, like earthworms, have all the sex tools; one set at one end, and the 'complimentary' set at the other end. So they can f*^% themselves :biggrin: )
Posted on: 2014/2/10 20:33
