248 user(s) are online (113 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
woody3882 Oil Pan dilema, please HELP
Florida
51 Posts
I really screwed up and need expert advise, Please..
After many months of restorinfg my 94 c-4 LT-1 I was only hours away from completion then it happened. I was replacing the OIL LEVEL SENSOR inserted on the side of the oil pan. As I was removing the old sensor from the pan, the small plastic retainer on the end of the sensor broke off and fell into the oil pan. Does this mean that I have to drop the oil pan (which I dread the thought of doing) or will the retainer just settle on the bottom. The retainer is made of plastic and is a bit smaller than a dime. Is there a screen on the oil pick-up tube that will prevent the retainer from doing any internal damage. Thank you to any and all for advise, I do appreciate it. I am at witts end...
Woody3882@aol.com
Posted on: 2013/1/17 23:19
FICINJECTORS Re: Oil Pan dilema, please HELP
Gold Sponsor Vendor
117 Posts
No worries, there's a screen and it will live there. I was found a shorty 7/16 wrench in the bottom of a lt1 that was there for years
Posted on: 2013/1/17 23:35
