531 user(s) are online (73 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
33k Toyota V6 3 Injectors click, 3 make bell-like sound and click
3 Posts
I just swapped out my Toyota V6 Denso 297-0019 injectors with
reconditioned FIC injectors and the FIC injectors are working GREAT! Thank you! My idle went from 665 to 645, cool! And engine is smoother.
I have a question about the injectors I just pulled. They are all Toyota part 23250-31050, which is Denso 297-0019. I hooked up some alligator clips and a 9 volt battery to listen to them individually. 3 click with a simple clicking sound, but the other three have a bell-like sound when they click.
Resistance tests show 9.65 - 9.8 (50F ambient today in the garage) , should be 11.6 - 12.4
3 questions
1) What is the bell-like sound?
2) Why would all 6 go so far out of spec on the resistance (12 Ohm specs)? Shouldn't one or two go bad, not all 6? Car has 110k.
3) Are these injectors rebuildable?
Posted on: 2013/2/3 17:26
bogus Re: Toyota V6 3 Injectors click, 3 make bell-like sound and click
I have personally no clue the properties of a Denso injector... but I will be equally curious to see what FIC has to say on the subject.
In my world, Corvettes, we have to deal with a GM injector made by "Multech". It's ok, but they fail rather quickly... but they don't go all that far out of resistance, usually, they just gum up internally.
Posted on: 2013/2/3 20:05
33k Re: Toyota V6 3 Injectors click, 3 make bell-like sound and click
3 Posts
Ok, the ambient made a huge difference. I brought the injectors inside the house and now they have 12.3-12.4 Ohm.
This still doesn't explain the resonant, bell-like sound in 3 of them.
Posted on: 2013/2/5 20:54
I like your avatar.
I would suspect that something internal has worn away? Causing the echo effect?
Posted on: 2013/2/5 21:35
3 Posts
Well, I wish an expert would chime in. I guess they don;t know, either :p
Posted on: 2013/2/6 14:41
