| corvetteronw | Help with Bosch IIIs | ||
Jon, I purchased these from you for my 91 L98 but have now switched the car over to a modified LT1 intake manifold.
Just installed them using new fuel rail to injector O rings but I don't think they are seated far enough into the manifold. What can I do to make them seat properly? Thanks in advance for your help. |
Posted on: 2013/5/24 1:45
A VETERAN IS SOMEONE WHO AT ONE POINT WROTE A BLANK CHECK MADE PAYABLE TO THE UNITED STATES OF AMERICA FOR AN AMOUNT OF UP TO AND INCLUDING THEIR LIFE. |
Transfer
| Matatk | Re: Help with Bosch IIIs | ||
Why do you think they are not seated? Did you pressure test them by turning on the ignition and pressurizing the rail?
Posted on: 2013/5/24 3:13
Transfer
| corvetteronw | Re: Help with Bosch IIIs | ||
The unit is not mounted on the block/heads yet. Several here have said the upper O ring should be seated into the intake's port.
I have an e-ail in to Jon and waiting for an answer. |
Posted on: 2013/5/24 14:33
Transfer
| -=Jeff=- | Re: Help with Bosch IIIs | ||
the 3's are shorter then OEM, the o-ring needs to be int he hole of the intake for sealing, if you work the injector down into the intake, will it still seal at the top?
I seem to remember the Ford SVO injectors I had on my 89 w/miniram were the same, I did not use clips for them and just made sure they were sealed on the top and bottom once installed |
Posted on: 2013/6/6 13:45
Transfer
Transfer
