267 user(s) are online (161 user(s) are browsing Forums)
BrianCunningham Torque tube & clutches
Saw Wheeler Dealers work on a C5 last week.
https://www.motortrendondemand.com/det ... rvette-c5-z06/0_p35cu91u/
I get removing the Torque tube to change the clutch
I also get pulling the transaxle
But dropping the entire rear cradle with the suspension to change a clutch???
Did they at least change this on the later cars?
Posted on: 2018/11/15 0:51
teebee Re: Torque tube & clutches
12762 Posts
I don't think so, Brian.
Posted on: 2018/11/15 3:14
bogus Re: Torque tube & clutches
20878 Posts
Nope...
it takes 4+ hours to bleed the clutch, cause you gotta get into the torque tube assembly... exhaust and that plate have to come down. There is a fix, but it will wait until I replace the clutch on my C6.
Posted on: 2019/2/10 20:27
