303 user(s) are online (264 user(s) are browsing Forums)
383tpimachine L92 truck intake injectors
Corpus Christi
976 Posts
I am going with an L92 truck intake out of an 09 escalade but the 30lb injectors will not support my plans.
What injectors should I go with? I was thinking in the 39-42lb range.
Thanks
Posted on: 2010/5/14 23:29
FICINJECTORS Re: L92 truck intake injectors
Gold Sponsor Vendor
117 Posts
we use a 42 ls2 injector that will drop right in the rail . you will need wire adapters if you are using a wire harness from ls1 or earlier. what vehicle is this in.
Posted on: 2010/5/15 2:52
383tpimachine Re: L92 truck intake injectors
Corpus Christi
976 Posts
I have the whole L92 wiring harness. Do the LS2 injectors have the same connection as the L92?
dropping a lil love into my 85
Posted on: 2010/5/15 2:55
1970 El Camino-Awaiting LSX
pr0zac Re: L92 truck intake injectors
truck injectors use different injector plugs. cars use the standard bosch style plug like what your 85 has. here is a adapter harness.
Posted on: 2010/5/15 15:09
Corpus Christi
976 Posts
im looking for direct plug n play L92 injectors of at least 39lb
will the Ls2 connect to the FACTORY plugs for an 09 L92?
Posted on: 2010/5/16 2:37
l92 = truck engine
ls2 = car engine
cars and trucks have different injector connectors.
how many ways can you say no. trucks have the smaller connector. you are probably going to have to get the adapters above or get a custom harness or change the connectors on your current harness.
Posted on: 2010/5/16 2:49
Corpus Christi
976 Posts
chill out
I was going off what FIC posted about the 01 and earlier harness. I looked around on his sight and see what I will need to buy.
Thanks for the help.
Posted on: 2010/5/16 3:50
Gold Sponsor Vendor
117 Posts
pr0zac wrote:
l92 = truck engine
ls2 = car engine
just to clarify.. In 2008 and ups the trucks use the same (uscar) plug as the ls2-9 car engines. The mini delphi was discontinued in 2007
Posted on: 2010/5/19 1:35
