248 user(s) are online (209 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
Weavsvet Photobucket problems....
446 Posts
When I use Photobucket to post up a pic it works fine in the thread body. But when you click on the pic to enlarge it a separate window pops up and says "this image has been moved or replaced", which it hasn't been. What's up with that? Am I using the wrong link on PH or is it something here on Guru?
Thanks,
Posted on: 2010/6/9 10:40
Matatk Re: photobucket problems....
Use the "html" link for the pictures.
Posted on: 2010/6/9 11:31
DaleD Re: photobucket problems....
Cuyahoga Falls, Ohio
1389 Posts
Photobucket seems to be following youtube's model. At first both were simple, fast and very useful. Now both are big, bloated, slow, and barely useful.
Posted on: 2010/6/9 16:55
TommyT-Bone Re: photobucket problems....
Make sure you change the IMG to lower case img after inserting.
Posted on: 2010/6/9 17:19
Weavsvet Re: photobucket problems....
446 Posts
Ok guys, thanks! I'll try a couple of these suggestions next time I post a picture.
Posted on: 2010/6/9 22:21
Not necessary if you use the html code. At least not in firefox.
Dale - when did photobucket become complicated?
Posted on: 2010/6/10 2:18
Weavsvet Re: Photobucket problems....
446 Posts
The html code worked, thanks guys
Posted on: 2010/6/10 22:57
