313 user(s) are online (261 user(s) are browsing Forums)
rlandon91z28 Connector Type on my 1991 Z28 Camaro 5.7 TPI?
2 Posts
First I know this is a Corvete Forum, but I figured you could answer this question also with flying colors?
What is the conector type on a stock 1991 Camaro L98 5.7L TPI?
Is is a Jetronic or a USCAR?
Second some of my budys are buying the Ford Racing 24lb injectors for these stock TPI motors, what is your opinion of those injectors?
Posted on: 2010/7/18 4:40
383tpimachine Re: Connector Type on my 1991 Z28 Camaro 5.7 TPI?
Corpus Christi
976 Posts
I cant help you but FIC usually checks during the week so might not be until monday to get your answer.
Can you post pics of your maro? Im looking for a 3rd gen for a drag project
Posted on: 2010/7/18 5:46
1970 El Camino-Awaiting LSX
rlandon91z28 Re: Connector Type on my 1991 Z28 Camaro 5.7 TPI?
2 Posts
The Car has 96000 original miles on it,
It is a 1991 Z28 5.7L TPI,
I bought it 6 months ago!
It has custom paint to match the 1992 heritage anniversary addition!
So far I have added:
MSD 6AL, MSD8.5 wires, MSD coil, MSD Rotor and cap
Platinum plugs
Flowmaster Exhaust, with cat back Hedman shorty headers
Dual K & N Filters, with air foil
BBK 52MM Throtle Body
BBK Adjustable Pressure Regulator
Jet Stage 2 Chip
I'm looking to upgrade to 24lb injectors, my injectors are starting to seep.
Looking to do new runners, porting, and manifold next!
jpg  Rob's Camaro 1.jpg (52.67 KB)
2915_4c432578434b6.jpg 800X600 px
jpg  robs camaro 2.jpg (54.66 KB)
2915_4c432590a54a1.jpg 800X600 px
jpg  robs camaro 3.jpg (51.21 KB)
2915_4c4325c44995b.jpg 800X600 px
Posted on: 2010/7/18 16:11
1Fast04Vert Re: Connector Type on my 1991 Z28 Camaro 5.7 TPI?
Good looking ride. Like Travis said, Jon from FIC will check in at some point about the injectors. He had great service and excellent prices.
Posted on: 2010/7/18 16:39
Matatk Re: Connector Type on my 1991 Z28 Camaro 5.7 TPI?
You have jetronic / ev1 plugs ends.
As far as 24 lb ford injectors, they will work in your car if you have a chip burned for that and supporting mods.
Posted on: 2010/7/18 21:16
Corpus Christi
976 Posts
Very nice. I hope mine will look as nice.
As for the plans I would get a different intake altogether. With a FIRST, miniram, superram, or HSR you could much better performance. Porting the upper to match your 52mm wouldnt hurt tho
Posted on: 2010/7/19 4:49
