219 user(s) are online (101 user(s) are browsing Forums)
Does it work?
« 1 (2)
Matatk Re: Car broke down....
22959 Posts
Thanks, Bill. I emailed comp a minute ago and I'll wait to see what distributor gear they recommend. I also found an article in one of the car rags about checking the distributor height when installing it (I'll try that) and using assembly lube on the gear (which I didn't do!).
Read this:
http://www.circletrack.com/techarticl ... tion_practices/index.html
matthew
Posted on: 2010/10/22 19:00
bogus Re: Car broke down....
20878 Posts
Matatk wrote:
Talked to Rick for a few minutes and we kicked around a few ideas. I think I agree pulling the pan is the best idea, but I've already done three oil changes since the motor was new, and I didn't observe anything unusual. I also drained the oil the other day to check for fuel and didn't find any unusual contaminants. So I'm up in the air.
What we were more concerned with was what caused the damage. It is the fact that the distributor gear had 20 years and 90,000 miles on it already? Was it previously worn when I reinstalled it and I didn't inspect it closely enough? Or is my cam walking? Are there problems with my cam bearings?
So those are some real issues I have to deal with I'm gonna mull it over and see what I decide. I'm also going to email comp cams and see what they say.
Bronze is a very soft metal... rather forgiving, really. I wouldn't be surprised if the gear simply gnawed itself to death and the materials are all in the filter.
Posted on: 2010/10/22 19:06
BillH Re: Car broke down....
Read this:
matthew
Yea, I've done the heigth thing a few times but never had to shim a disty for it.
+ what Andy said about bronze.
If Comp recommends a composite, I wouldn't do it.
Posted on: 2010/10/22 19:12
22959 Posts
I didn't know the original distributor was bronze?
I think this is the GM version of the melonized gear:
http://www.gmpartsdirect.com/performa ... PRODID=610&CATID=608.html
Posted on: 2010/10/22 19:54
22959 Posts
I'm also gonna look into the shim kit....
Still waiting to see what comp recommends.
Posted on: 2010/10/22 20:00
I'm not sure about that.
Posted on: 2010/10/22 20:02
Matatk wrote:
I'm also gonna look into the shim kit.....
http://www.summitracing.com/search/?k ... =distributor%20shim&dds=1
Posted on: 2010/10/22 20:04
22959 Posts
I meant distributor gear. Because you said you agreed with Andy...
Article on adding an oiling slot to distributor:
http://www.hotrod.com/techarticles/en ... ification_tech/index.html
Posted on: 2010/10/22 20:15
Yea, I know. Me 2.
I not sure it was bronze from the factory, but if it was...
Steel ones will break too.
The oiling thing's good but for street and occasional high rpm, probably not necessary.
Posted on: 2010/10/22 20:35
CentralCoaster Re: Car broke down....
I agree, the metal that came off that is either in the filter, or there's a few teeth in the oil pan from when it finally went. Stick a magnetic drain plug in there and forget about it. (Yeah, I'm lazy)
What does the cam gear look like? Is it an aftermarket cam? I've seen some that had some nasty sharp edges out of the box and had to be filed smooth.
pr0zac Re: Car broke down....
sorry i wasn't really clear, i was suggesting an upgrade to a bronze gear.
Posted on: 2010/10/22 21:12
22959 Posts
Funny you mentioned that, I was looking at it right before you posted this. Visual inspection of the gear (while at TDC only) is good. I can see some minute shavings from the dizzy gear on there, but the cam gear looks good. BTW, it's difficult to photograph.
Photobucket
Posted on: 2010/10/22 21:47
22959 Posts
Response from comp cams:
If there was any damage to the cam, you would be able to see it while it is
still in the engine. That looks like the normal wear with a high volume oil
pump and stock gear. The correct material is iron or steel, but it has to be
melonized. That is the process that makes the gear compatible with our cams.
Now the wear issue will still be there with a high volume oil pump, which is
inevitable, but it may not be as bad with the correct gear. I also spoke to
one of our engine builders and he said that the original gear was worn with
the original cam, and then it was put on a new cam, so that was most of the
culprit. As long as the cam gear isn't damaged, I would recommend the GM
part # 10456413 distributor gear and some gear marking compound just to make
sure the gears mesh correctly. Thanks,
In an effort to handle the overwhelming volume of e-mails we recieve, please
limit your replies and if a reply is necessary, please reply to the original
and ask all questions in one e-mail. Thank You
William Hood
Technical Consultant
flyboy Re: Car broke down....
RickAnthony wrote:
[quote]
Also have you checked to make sure the dist. shaft is still turning? I'd pull the cap off and have someone crank it and watch to make sure it's spinning like it should. We've seen some strange failures on dist. drive gears lately.
-=Rick
Good call Rick.
I hope the cam is O.K. and no major disassembly to be done.
Posted on: 2010/10/22 22:43
RickAnthony Re: Car broke down....
ASE Master Certified
Downers Grove, IL
703 Posts
flyboy wrote:
RickAnthony wrote:
[quote]
-=Rick
Good call Rick.
Thanks, just hoping everthing else is ok... yea he spent alot of money on this motor, and yes it's a pain to pull the pan off and tear the motor down. And he sold his engine hoist.. so alot of things to consider towards what the next step is.. change the oil & filter, replace the gear hope for the best or tear it all down again?
-=Rick
Posted on: 2010/10/23 0:19
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
20878 Posts
What is the oils direction at this point? Is it still going up or falling down? I can't remember.
Either way, big chunks would have been beaten to dust, and dust won't harm much of anything.
I would pull the pan and pump. Make sure there isn't any gauling on the pump gears. Replace if necessary.
But if I remember, the oil is falling down at this point, so its next stop is the pan. IIRC, it's from the pan into the filter... I just don't remember off hand.
I would then do an oil change with cheap oil, and the existing filter. Run that for 10 miles or so, then switch back to the good stuff.
Finally, take the original oil and the replacement cheap oil and get them both tested for contaminatents.
Posted on: 2010/10/23 1:42
That chewed up gear does not look like bronze to me.
Maybe I'm missing something. I know some aftermarket cams require a certain type of distributor gear material and some last longer than others. Apparently this gear was the wrong material or something wasn't lined up proper.
Posted on: 2010/10/23 3:22
22959 Posts
Read the email above from comp - it's the right material, just mismatched due to the old cam. I talked to my dad about it, too. He's been a machinist in the car industry for 30 years. When you mate two gears, they develop a certain pattern together. When you change one of those gears (in my case the cam gear), that pattern changes and it wears the metal. I am pretty confident a new dizzy gear, properly installed and checked will be fine.
Posted on: 2010/10/23 4:33
Wow! I'm sure the new cam old dist. gear combo has been done thousands of times with good results. I guess you got the short straw this time. I better look at mine, although the gear looked new to the eye and it's a G.M. cam. Hope you get it sorted out. Good thing you baby proofed the garage with the new floor coating.
Posted on: 2010/10/23 13:04
Yep
Posted on: 2010/10/23 13:24
22959 Posts
I've found a lot of anecdotal evidence online of the same problem I had. It's not uncommon in the least bit. Since you changed the your cam, I would recommend pulling the dizzy and checking the drive gear. A new GM gear is around $45-50. Better to have the piece of mind. From what I've read, too, guys "in the know" always change the gear whenever they change their cam. Something to consider.
Posted on: 2010/10/23 13:35
22959 Posts
Another thing I learned about the melonzied gears. The melonization is a treatment process for the steel gear. It makes the outside of the gear harder yet with better friction qualities.
http://www.burlingtoneng.com/melonite.html
Also, from reading online, GM requires the melonized gear on all of their crate engines with roller cams.
Posted on: 2010/10/23 13:46
It's on my agenda. I do have my drain oil tested, nothing abnormal, so that's a good sign.
Posted on: 2010/10/23 14:18
PeteK Re: Car broke down....
Yup. In my opinion, once a distributor gear and cam gear are married, they are a pair for life. New cam = new dist gear. I learned it the hard way.
Posted on: 2010/10/23 14:45
rayquayle Re: Car broke down....
139 Posts
This is excellent and timely info for me. I'm just about to install a new cam in my flat tappet L98. Guess I'll put a new distributor gear on my order list. Sorry to hear about your problem Matt, but what you've learned and shared is a help to me.
Posted on: 2010/10/23 17:09
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
22959 Posts
Ray - from what I read, the flat tappet cams use a different material on the cam gear, so you just use a standard cast iron distributor gear.
Read this:
http://www.carcraft.com/techarticles/distributor_gears/index.html
And this:
http://www.enginebuildermag.com/Artic ... and_distributor_gear.aspx
Properly Matching Your Camshaft and Distributor Gear
Matching camshaft and distributor gears is one of the most critical, yet often overlooked step in engine assembly. The proper distributor gear for your camshaft differs by both the material and the kind of lifter for which your camshaft was designed. Using the wrong material can lead to premature gear wear, possible camshaft wear and ultimately engine failure.
First off, no steel distributor gear is compatible with both flat tappet and hydraulic roller cams. This is because hydraulic rollers can be made from two possible materials and either of those materials requires a different gear than the flat tappet cam. Regardless, a steel gear is not compatible with a cast iron flat tappet cam.
Distributor Gear Materials:
1. Cast Iron
2. Composite (offers great life, conforms well to the mating cam gear, and is compatible with ANY camshaft gear material)
3. Melonized or hardened steel (material that OEMs use with factory roller cams; many aftermarket distributor manufacturers use these as the default gears for their distributors)
4. Bronze (conforms well to the mating camshaft gear and will not damage the camshaft gear, but it is a self sacrificing gear intended to be used in race applications only and should be replaced about once a year)
If you have a cast iron hydraulic or solid flat tappet cam, your distributor gear options are:
1. Cast iron distributor gear
2. Composite distributor gear
If you have an austempered ductile iron hydraulic or solid roller cam, your two options are:
1. Melonized or hardened steel distributor gear
If you have a billet steel hydraulic or solid roller cam, your two options are:
1. Bronze distributor gear
COMP Cams recommends the composite gear because it is compatible with all camshaft gears – flat tappet, austempered cast iron cores, and billet cores. If the steel gear is not hardened, it is not compatible with either of the roller cam types.
Note: If you have an austempered core hydraulic roller cam and a .500˝ shaft distributor with a steel gear, verify with the manufacturer of the distributor that the steel gear they use is a melonized or hardened steel material and it will work fine.
–Tech Tip courtesy of Comp Cams
Posted on: 2010/10/23 17:51
139 Posts
Thanks for that Matt. I was confident both gears were iron, but assumed that the iron gears also mate and should be changed when installing a new cam. I guess it's cheap insurance.
Posted on: 2010/10/24 16:50
NCM Founder #2896
NCM Lifetime #672
22959 Posts
Well, good news, everyone. Got a chance to tinker with the car today. New drive gear and reassembled everything and it fired up. Set the timing and it's running like a champ. I'll do a nice post later about overhauling your distributor
Posted on: 2010/10/31 19:58
TommyT-Bone Re: Car broke down....
34424 Posts
Posted on: 2010/10/31 21:12
Downers Grove, IL
703 Posts
GOOD NEWS!
Posted on: 2010/10/31 22:39
My Automotive Blog
biggrizzly Re: Car broke down....
Great News! Nice to hear that thing running again, isn't it?
Posted on: 2010/11/1 1:56
20878 Posts
yay!
Posted on: 2010/11/1 1:57
Downers Grove, IL
703 Posts
BTW Now that you got the car going.. want to rebuild my trans with me LoL... I may pull it next weekend not sure yet.
Posted on: 2010/11/1 1:59
My Automotive Blog
22959 Posts
Yes, because I think when mine goes again I'll rebuild it myself with one of the high hp kits.
Posted on: 2010/11/1 2:17
I have given this some thought as well. I wonder how hard it would be with the carefull guidance of PeteK?
Mine is out and a good candidate, why don't you guys come on over next weekend?
Posted on: 2010/11/1 3:24
Downers Grove, IL
703 Posts
biggrizzly wrote:
I've done my 4L60E before along with my wifes (now my mother inlaws) Denali and a few others... I drive my car hard and they only hold up to the abuse for so long.. This time I was doing a decent burnout followed by a 1/4 mile run, felt it slipping on my launch a bit. Then after it was slipping a bit just driving back to the pits.
I know Matt would like to see what is involved with the power his car is making it's no doubt a trans rebuild will come up again at some point.
Trans work is not hard at all time consuming yes, the main thing is putting everything together with care & in the correct order and direction, don't damage seals when you install them. Check everything for wear, tear operation ect. As my trans teacher said, if you do everything correctly there is no reason it should not work.
-=Rick
Posted on: 2010/11/1 4:28
My Automotive Blog
Downers Grove, IL
703 Posts
Cool, I was thinking of ordering everything I need but I decided I'm going to hold off till I tear it apart.. I really doubt anything is broken, most likely jut burned clutches. I'm going to send my torque converter in most likely as well. May change the stall speed not sure yet, and have them check it or rebuild it ect.
-=Rick
Posted on: 2010/11/1 4:33
My Automotive Blog
flyboy wrote:
I finally got around to checking the gear. No abnormal wear after 10k miles, so that's a relief. Don't know if the fact that it's a GM cam/gear makes any difference but I'm glad I checked.
jpg  P1010002.JPG (145.45 KB)
1735_4ce97c0d5e67f.jpg 640X480 px
Posted on: 2010/11/21 20:07
22959 Posts
Glad your cam gear is holding up fine, Joe. Did you do the oiling mod to the distributor like in that article above? I made sure to do mine just for extra insurance.
Posted on: 2010/11/21 21:55
Hmmm... filing the .030"X.030" vertical groove into the bottom machined band just above the gear? Nope, missed that, but I will next time it's out.
Posted on: 2010/11/22 0:03
« 1 (2)
