295 user(s) are online (254 user(s) are browsing Forums)
JDSWHITE93 horn button 1980
Ohio
334 Posts
So I bought a red on red 1980 L82 car The horn button is not right, it fell off after the horn starts honking while turning. Anybody have a diagram of how this thing is supposed to go back together so the horn works correctly ? The previous owner put a new steering wheel on it and there lies the problem, hack...
jpg  1980 CORVETTE.jpg (0.00 KB)
Posted on: 2011/1/15 23:45
bogus Re: horn button 1980
yuck... I would PM Durango_Boy or Curtis74.
Posted on: 2011/1/16 0:01
JDSWHITE93 Re: horn button 1980
Ohio
334 Posts
Thanks ! I bought it without actually seeing it as it came out of Texas so I am FIXING this guys FIXES lol
Posted on: 2011/1/16 0:24
Durango_Boy Re: horn button 1980
With a light tug on the bottom of the wheel, does the whole column move slightly down and to the left or right?
Posted on: 2011/1/16 0:49
Ohio
334 Posts
dunno yet....., the horn button fell off and there's shit moving around though, if you play move the metal pieces around the horn will sound.... I'll check it tomm. and see if the whole thing is moving.
Posted on: 2011/1/16 3:12
BillH Re: horn button 1980
Sounds like something's grpunding in there. That's all that happens when you push down on the horn button, the button makes a ground contact which energizes the horn relay.
If something's loose in the upper column/wheel, it may be an easy fix.
Posted on: 2011/1/16 14:05
Yeah it's one of two places. Upper wheel assembly that's easy to get to. Hopefully that's all it is. I've dealt with a harder fix before, where some of the plastic sleeves in the column had cracked from too much pulling on the wheel...like how older folks get in and out of their Vettes...and the wire was pinched and grounding out when the column had pressure put on it.
Upper column is easy, the other requires a rebuild, with a lot of hard to find parts and patience.
Posted on: 2011/1/16 14:41
Ohio
334 Posts
How does this go back at together ??? I ran the three screws into the spacer as not to lose them
[IMG]http://i52.tinypic.com/1zps0hd.jpg[/IMG]
Posted on: 2011/1/16 19:55
Ohio
334 Posts
[IMG]http://i52.tinypic.com/352own4.jpg[/IMG]
Posted on: 2011/1/16 20:04
Will this help a little bit?
[IMG]http://i106.photobucket.com/albums/m242/durango_boy/ColumnBlowup.jpg[/IMG]
Posted on: 2011/1/16 21:21
Matatk Re: horn button 1980
22803 Posts
I have good photos and a write up in this link:
http://www.corvette-guru.com/modules/ ... id=103193#forumpost103193
You also need to google Jim Shea and download all of his articles on c3 steering columns.
Posted on: 2011/1/16 23:27
Ohio
334 Posts
It's missing the plastic rivets is what it's missing. Now I can put it back together the right way... Whew !!
Posted on: 2011/1/18 3:19
22803 Posts
Glad you found it. Hope the info we posted helped?
Posted on: 2011/1/18 12:36
Ohio
334 Posts
YEP... SURE DID
Posted on: 2011/1/18 16:46
