193 user(s) are online (63 user(s) are browsing Forums)
Steve40th 4 Sale: LT1/4 Offset oil filter adapter. 40.00 dollars
1114 Posts
This is for the 94-97 LT1/4 but will fit 92/93. The difference is the bolt length. The 92/93 uses about a 3 inch long bolt, and this one uses a 1.875 inch long 5/16 18 bolt.
I had two but the bolts I had was for the other one, so now I have a spare, for sale here. I believe I have extra gaskets, but at GM they are only a few bucks. I have no bolts, but they are easy to get at any decent nut/bolt shop. GM Bolt part number PN 14092398, gaskets part number GM 88893990.
Steve
Posted on: 2011/2/28 7:32
Ko'u ohana aia ku'a ikaika
Unclemormon Re: 4 Sale: LT1/4 Offset oil filter adapter. 40.00 dollars
San Jose
1 Posts
Hi Steve,
Is this GM part #10215675? If so, I will buy this part immediately if it is still available?
Thanks you
Posted on: 2015/12/9 14:31
Matatk Re: 4 Sale: LT1/4 Offset oil filter adapter. 40.00 dollars
22803 Posts
This post is from 2011, and the original poster hasn't logged on since 2013.
Good luck with your search.
Posted on: 2015/12/9 16:27
bogus Re: 4 Sale: LT1/4 Offset oil filter adapter. 40.00 dollars
Hm... need to yell at Steve...
Posted on: 2015/12/9 17:16
