293 user(s) are online (262 user(s) are browsing Forums)
Anonymous '84 starter location, need help!
35 Posts
I don't know cars all that well and I am slowly learning and getting better and problem solving them. I need help though. My '84 vette won't start anymore and I think it has to do with the starter or the solenoid. I tried to start it one day and it would not turn over and made that clicking sound. Then a week went by and I tried it again but the battery was completely drained. I charged it and it started(baffled) and moved it to my garage, but of course after that day it would not start again, then eventually the batt. was completely drained again. I am not sure what the problem is anymore but still think it might be the solenoid or the starter.
Anybody have any comments or solutions to this problem?
I can't find the stupid starter. I have a Hanes manual for '84 vettes through '96 all the C4's, but it does not illustrate very well of where the location is. Thats my biggest problem because I want to take it out and have it tested to make sure that is the problem.
thanks,
Jeff
Posted on: 2005/12/16 0:06
brut RE:'84 starter location, need help!
New Albany, IN
1308 Posts
First off, welcome to C4guru!
I could be wrong here, but it sounds like your battery is bad and not your Starter. I would pull it out and have it tested. Or better yet, get it started and drive it to a place like Autozone and they should be able to do a quick test of it and the Alternator while it is still in the car.
If both of those turn out to be OK, and you want to pull the starter itself.....
It will be on the bottom of the passenger side of the block. It will be right where the engine and tranny meet. A novice could pull it out with a little patience...just remember to UNHOOK BATTERY FIRST!!! Those cable you pulloff will be live and if they touch metal....that could be bad!!
Good luck!
Posted on: 2005/12/16 0:44
Anonymous gratefull
35 Posts
Thank you very much that helped me out a lot!
Thanks,
Jeff
Posted on: 2005/12/16 0:56
bogus RE:'84 starter location, need help!
I agree. check the battery first.
And welcome!!!!
Posted on: 2005/12/17 3:05
