LittleBill | Corvette mechanic | ||
Ok, I am in Allendale- between Grand Rapids, Muskegon , Holland. I need to know of a reputable Corvette mechanic or dealership for service if and when I need something done to my 94 vette. Recommendations? I do not need service right now but would like to know in advance where to go or who to talk with about the Vette.
thanks |
Posted on: 2011/7/26 0:40
bogus | Re: Corvette mechanic | ||
One of our members, RickAnthony, has a shop in the Chicago area.
As for your area, I don't know of anyone. What kind of work are you after? Basic maintenance? If so, that is rather simple. Most any good auto mechanic that you trust should easily be able to handle that. If it gets complex, a combo of his/her experience, plus the Factory Service Manual and our help, there isn't much we can't solve. |
Posted on: 2011/7/26 1:33
LittleBill | Re: Corvette mechanic | ||
Not sure what I will run into, just want to know that if needed I can go to someone reliable and have the problem solved. Thanks for your input
Posted on: 2011/7/27 1:02
Matatk | Re: Corvette mechanic | ||
Here is the website to the Grand Valley Corvette Association - they are in your area and could probably recommend someone close.
http://grandvalleycorvette.org/ Good luck and welcome to the site. Matthew |
Posted on: 2011/7/27 2:32
BrianCunningham | Re: Corvette mechanic | ||
used to belong to the Corvette Club of Michigan.
They may know of someone good reason to join a local Corvette club. |
Posted on: 2011/7/27 2:36
