272 user(s) are online (234 user(s) are browsing Forums)
kehler POWER STEERING COOLER
Pembroke, NH
4 Posts
Ok so my cars away for the winter (84). While its parked I plan on replacing my rack and pinion with a reman. I'm going to upgrade to the Z51 rack. I have also bought a PS cooler. Can anyone tell me where this is located or post pictures. While I'm doing this work I was also going to add a filter. Is there an issue with adding the filter and cooler with the power steering pump I presently have?
any input is appreciated
Thanks
Posted on: 2005/12/16 16:13
bogus RE:POWER STEERING COOLER
welcome aboard!
Answering in order:
The cooler is a great idea! It is mounted on the front of the k-frame behind the under car intake.
So is the filter! It must be mounted to the low presure side.
Question - is this a factory or aftermarket cooler? I would track down the GM parts for a factroy cooler. It works well, and I suspect new hoses would be nearly required at this time.
Posted on: 2005/12/17 2:44
