NC Kid | Grommet that goes in valve cover | ||
The passenger side has a hole in the valve cover with a hose that leads to the throttle body. The rubber gromet that goes in the TB is shot. I can't find one that fits right. Someone told me to put a breather on it but that still doesn't get the air to the throttle body.
Posted on: 2012/3/19 23:35
vetteoz | Re: Grommet that goes in valve cover | ||
Air doesn't go to TB ; it comes FROM TB port as supply air for the PCV system which exits through PCV valve in drv side cover. Engine fumes only go back to TB from pass side cover at WOT when no vac in system If a MAP car breather is no problem If a MAF car ,breather allows non metered air into engine ( a vac leak ) |
Posted on: 2012/3/20 0:59
bogus | Re: Grommet that goes in valve cover | ||
Ecklers does not show it.
I know the part. Call Chris May at Superior Chevy. 1.800.728.8267. |
Posted on: 2012/3/20 3:35
NC Kid | Re: Grommet that goes in valve cover | ||
called a few times. No answer then finially someone picked up. Said he couldn't get a hold of him??? Asked about grommet and said they were discontinued. Called my dealer..Guy said he had no idea what I was talking about....Wow..... |
Posted on: 2012/3/20 16:06
BillH | Re: Grommet that goes in valve cover | ||
Posted on: 2012/3/20 16:18
Matatk | Re: Grommet that goes in valve cover | ||
Are you referring to the hose itself or the grommet in the valve cover? There is no grommet for the TB, it it a metal nipple that extends out of the TB. You can get a replacement grommet in the help section at any parts store. If you can't find an exact one, get one a size bigger, slice it in the middle and cut out the section needed to make it fit. Matthew |
Posted on: 2012/3/20 22:29
Thanks. I did that. It's not a great fit but it'll do better than the old one. Just hadnt logged back in to update. |
Posted on: 2012/3/26 18:33
