256 user(s) are online (220 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Collector Edition
RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
chisgt Brand new AC Delco HEI Distributor - $115
chitown
58 Posts
This distributor has the melonized cam drive gear P/N 10456413 for steel roller camshafts. This distributor is required on all crate engines and roller camshafts that are made of steel. Use connector wire P/N 8917052 to ignition. Distributor- Part # 93440806 GM HEI Large Cap style with internal Ignition Coil. Timing Should be Set @ 32° Total @ 3,000 RPM With Vacuum Advance Disconnected. 10° initial timing at idle should provide this total. Vacuum Advance should be connected to a ported source at the carburetor. This is a brand new in the box Hei Distributor. $115.00 obo Call Tim 773-551-6914, Plus shipping if not picking up
Posted on: 2012/5/30 2:22
