NC Kid | 5000K Projector HID headlight system. | ||
HID headlights. Retailed at over 1000 a set. You get everything you need to plug these bad boys in....No headlight motors or covers are included. You have to reuse your own motors and cover. Duh, the cover is the color of your car now....
5000K 35 watt ballast made of stainless steel. Clear lenses. Hardly used. Low/High beam. Projector casing made for HID bulb. Custom made for the C4 vette. Came from an 86. Not sure what it fits up to. I believe 88. http://www.corvettehid.com/cart/index ... aedf456829e3b14de7d9dc60b 875.00 shipped to the lower 48 states but I am willing to hear reasonable offers. If your not truely interested in purchasing them, then don't post...Want to keep it a clean thread for serious buyers only. Thank you!!!!!!! I am going a different route that will be even better for me. I can tack on the headlight motors for a little bit of extra $$$. P.S. When I say hardly used, I truely mean used like two times. Very very bright.... |
Posted on: 2012/10/2 15:58
bogus | Re: 5000K Projector HID headlight system. | ||
If this is a bulb based solution, then it will fit all years. Wiring mods may be required...
Posted on: 2012/10/2 16:07
NC Kid | Re: 5000K Projector HID headlight system. | ||
Negative. This replaces your entire projector. No oem housing. Made from scratch....
Posted on: 2012/10/2 16:30
Still didn't quite catch my point... it replaces the OEM sealed beam. Which means it will fit all years, save some minor wiring variations.
I looked at the picture, and it might be a new housing, but it replaces the sealed beam. |
Posted on: 2012/10/2 19:17
