291 user(s) are online (252 user(s) are browsing Forums)
Also known as the DIC.
corvetteronw Help with Bosch IIIs
Lowell, MI
Jon, I purchased these from you for my 91 L98 but have now switched the car over to a modified LT1 intake manifold.
Just installed them using new fuel rail to injector O rings but I don't think they are seated far enough into the manifold.
What can I do to make them seat properly?
Thanks in advance for your help.
Posted on: 2013/5/24 1:45
Matatk Re: Help with Bosch IIIs
Why do you think they are not seated? Did you pressure test them by turning on the ignition and pressurizing the rail?
Posted on: 2013/5/24 3:13
corvetteronw Re: Help with Bosch IIIs
Lowell, MI
The unit is not mounted on the block/heads yet. Several here have said the upper O ring should be seated into the intake's port.
I have an e-ail in to Jon and waiting for an answer.
Posted on: 2013/5/24 14:33
-=Jeff=- Re: Help with Bosch IIIs
Bartlett, IL
573 Posts
the 3's are shorter then OEM, the o-ring needs to be int he hole of the intake for sealing, if you work the injector down into the intake, will it still seal at the top?
I seem to remember the Ford SVO injectors I had on my 89 w/miniram were the same, I did not use clips for them and just made sure they were sealed on the top and bottom once installed
Posted on: 2013/6/6 13:45
-=Jeff=-
1990 Corvette ZR-1 #1051
