200 user(s) are online (168 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
NelsonV Tightening control arm pivot bolts?
Sunny Southern CA
245 Posts
A friend of mine brought up this issue; not something I've ever considered....
http://www.tirereview.com/bushing-tes ... ll-when-a-bushing-is-bad/
A common error for a technician is to install a control arm, then torque the pivot bolt while still on the four-post lift. While on the lift, the suspension is at the end of its travel. If the technician torques the pivot bolt under those conditions, when the vehicle is lowered, the bushing will be in a constant twist. That condition is a death sentence to the bushing, one that may be carried out at the first good bounce of the suspension. That scenario is not an issue for polyurethane designs. Strut rod and radius arm bushings should be replaced in pairs to prevent great differences in caster between sides.
Real or ultra-conservative issue?
Posted on: 2015/2/27 20:43
bogus Re: Tightening control arm pivot bolts?
I can see this... had similar problems with RC car suspensions if they were tightened in the wrong part of the arc.
Posted on: 2015/2/27 22:07
BrianCunningham Re: Tightening control arm pivot bolts?
True, autocrossers go to great length, to take all the tension out of the system
Posted on: 2015/2/27 22:18
BillH Re: Tightening control arm pivot bolts?
Actually - Ultra Real
Tightening the bolts with the wheels in full droop is a very bad idea.
This also applies to the rear suspension components.
And for example, on a C2, if you tighten the spring mount bolts that hold the leaf spring to the rear end housing without the car weight, you stand a very good chance of breaking the rear end housing.
And - always use a torque wrench.
Posted on: 2015/5/24 16:09
CentralCoaster Re: Tightening control arm pivot bolts?
Correct, the factory rubber is bonded to the metal.
I don't get It, because it doesn't seem like it allows for enough movement, and bushing stretch should not be dictating your wheel rate, the spring is much more consistent
Posted on: 2015/5/26 2:38
