328 user(s) are online (270 user(s) are browsing Forums)
Transverse Leaf Spring
pappyfreebird got r 2 daze of summer
1028 Posts
and now think my drivers side ac is a tiny bit warmer then pas side..and dont think its as cold overall...touch low on freon or some other lectric chit goin on ..pass side will change warmer colder etc..dont feel diff in my side..read somewehre once that real beeyutch pullin chit apart n ened up beyun lil shy on freon n was writtun that pass sides colder then usully jus freon...what think fellas 97 c5
Posted on: 2015/8/6 17:29
bogus Re: got r 2 daze of summer
I would add some 134... and go from there.
The diagnostics might be able to help you. I will have to check my service manual.
Posted on: 2015/8/6 18:15
pappyfreebird Re: got r 2 daze of summer
1028 Posts
thanks bro bog..i r thinkin tis either a touch low (hopin so) but read 24lbs er um in green on the cheapo can low pressure gauge..but was hooked to empty can..lil freon n mabee reset controller by pullin # 27 fuse (fer anybody same spot) cd i have sez set drivers side to 60 pass to 12 oclock or centerd then switch off pull 27 fuse (pass floorboard box) fer least 60 seconds n hopefully then hear actuator doors resset as plug in..seems read before pass side still cold drivers is cool or warmer means low freaon yet no blicking light er codes as barley low..i knowd compressore stays on so again ..do lil freon n er mabee pull fuse 1st as is free n go from thar...fugan a 2 daze of summar n muy air fugs up in one of them wahahahaha
Posted on: 2015/8/6 19:11
1028 Posts
ok i did the reset actuator thing (pulled fuse) no diff..still cool air but pass side lil cooler n doesnt seem up ta snuff, but comparing to 07 yukon n a 14 taurus n they kick azz,,got can 134 ,chit chit dumped half can thinkin prolly empty,,woulda been nuff ..anyways new can opind n tooks jus a squirt (typo earlier at 24lbs was 42 ,,yes i r azzbackwards) now at 45on the cheapo low pressure gauge but is colder..new question..how kin a system thats lowest is 60 git to 40? stealin her candy themro unit now her side pass> gits 55 reg 52 cab air..drivers still lil warmer 58 reg n 55 cab air ...but seems cold again ..any input be great rednecks..i really dont wanna be hot on me 2 daze summar..
Posted on: 2015/8/6 20:59
1028 Posts
ok strike de dipstick ? of thermo ony goes to 60 how git 40..vents should still put out 40-50 degreezers n that depends on 500 variables of humidtity n chit like that..i pumped in touch more to 48 lbs low side n shes 1 degree apart now n that was high 90s humidtity 93% now n was cold as hell at 5am 73 temps ,,so ifn yer drivers side blows lil warmer er is warm compared to her side (pass side) resest fuse cheapest but was freon next cheapest..now blows 50 drivers 48 9 ish pass side runnin down rode in very high humidtity,,leave temp gauge aside n will be thrilled like de ol truck squirt some in gits cold fug it enjoy it..
Posted on: 2015/8/7 12:15
1028 Posts
well my coolness were chort lived redneck vetters..compressor looks awful oily,,but over couple daze leaked enough somewhere that comp wouldnt come on n got the blinkee ac light ,,added 1/2 had left n took off werkin so she has a leak somewhere..anybody feel free to danate ta da make pappy rich n famous foundation c/o make pappy cool awrighty
ps im purty good wid a wrench ifn forced how many yous bruthas changed out c5 compressor..gues i did c4 rack n pinion waater pump etc..but i jus dont have de urge
Posted on: 2015/8/11 1:21
pianoguy Re: got r 2 daze of summer
On the bright side, it looks like a great day to roll down the windows, Pappy ;-)
Good luck!
Posted on: 2015/8/11 10:30
1028 Posts
mabee that day bro,,but taday is a wet swampy day ain it...one thang i kin say fer chure is my new to me (bus) yukon slt2 is very noice rig n super cold air n nawt one niose in cab (lucky guy right)well will update but broke pride n have c5 at local shop 840 bucks fer 5 yr warrenty air con kit (comp acume drier n screen) installed filled etc,,now lets see ifn i git by at 840.ida saved 3-400 doin it in own shop..but stoopin over that lowrider ain no good fer bad back
Posted on: 2015/8/14 11:57
teebee Re: got r 2 daze of summer
12364 Posts
Sometimes, Pappy, it's cheaper to let someone else fix it.
Posted on: 2015/8/14 12:24
1028 Posts
i hear ya brutha tee but i aways figured evin ifn ony save 20 n tooks 4 hrs tis still 20 saved n pride of i did it meself,,nw i r first to say when borin ol hog cyl matchun psitons etc pay de mayun that do em everyday,,but kin still put em meslf ,,but like ya said then thars times when hey pistons n new heads,,,let him mount em n ifn issue let him fight factory n fix em..you mount em n its oh well wtf did you do to em..so yea i hear ya...r n r n flush aw well least i wont have a back ache n i rekon i werk nuff fixun ol hogs to pay once in awhilst ..so now jus hope done taday n mabee evin cheaper (yea you high brotha paps) dat ain gonna appin,,well one kin aways have hope my bruthas...
Posted on: 2015/8/14 19:01
1028 Posts
does de hot broke pappy saga stop here ,,i r hopin so bruthas..1050. denaroos total ..new comp kit dryer etc,,went up cause theyd called n sez water pump may have had a tiny leak once had a stain i sez replace it too so nuther 146 n 20 fer tstat,,in seeyun water pump they ain jack wrong wid it ain hurting de shop is a tiny lil stain whitish in color,,so i have a pare pump now i rekon..is she cold now well compared to r new chit no but fer 20 yrs yeup she do de job
Posted on: 2015/8/15 16:49
12364 Posts
Ain't that a kick in the balls. Well, I guess you're all setup for a while now pappy.
Posted on: 2015/8/16 12:50
