441 user(s) are online (213 user(s) are browsing Forums)
Geardo 87 no crank condition
6 Posts
My 87 will not crank, get no click on the starter, I have 12 volts to the starter. bypassed the security relay in the dash, still no crank
Posted on: 2015/9/5 15:55
bogus Re: 87 no crank condition
20883 Posts
volts are only part of the equation...
Have you had the battery tested?
The starter?
Check the leads at both ends, heavy corrosion will cause current loss, making it harder to start.
Age plays a major factor here...
Also, make sure the nuts/bolts are all tight.
Posted on: 2015/9/5 18:04
BillH Re: 87 no crank condition
Put the volt meter on the small wire (stud) on the starter solenoid and have someone turn the key to "start".
Got 12v there?
Posted on: 2015/9/5 18:10
captmike13 Re: 87 no crank condition
Holden Mo
2182 Posts
Auto or stick? This makes a difference too.
Posted on: 2015/9/6 2:15
13 GMC 3500 dually
2015 VW Pissant
2003 Goldwing
I miss my Vette
captmike13@yahoo.com
CentralCoaster Re: 87 no crank condition
If it passed bills test then yes you probably have a bad battery or bad cable/connection. A bad connection can pass voltage but not enough current.
Posted on: 2015/10/25 20:20
