211 user(s) are online (175 user(s) are browsing Forums)
« 1 (2) 3 4 »
Schrade Re: Help on CCM pull...
Matatk wrote:
Schrade wrote:
Dash out; no broken tabs. The sticky / shock pad gave me fits (D side, forward). Thought I was missing a screw to remove...
Do I spy an A/C Programmer Module in the Yellow circle???
LTPWS
Yup - not your first day obviously...
Thanks on Programmer link - sure hope I can confirm that that's the problem. (and it HAS TO be for my '90, as well as '90 L98 ? )
Posted on: 2016/1/8 20:06
Matatk Re: Help on CCM pull...
As far as I know it should fit both. I will try to verify that later.
Posted on: 2016/1/8 21:03
Nope - of COURSE NOT. Too easy access.
THat's the chime module.
Schrade wrote:
Or is THIS my Programmer??? UGH.........
Posted on: 2016/1/10 19:13
Of COURSE not so lucky as one of those 2 modules. It's BEHIND the Instrument Cluster.
And IC is NOT coming out as did the '94 IC, OR the '87 IC. Looks like AT LEAST steering wheel bezel and dash frame will need to come out.
ChuckB is rapidly EXPONENTIALLY approaching 'the' point...
aka; As Is, Where Is.
edit: Then again, maybe not 'AIWI' ('til tomorrow anyway)
I/C out. Correct orientation got it out nice n easy. Just like '94...
Posted on: 2016/1/10 19:54
Edited by Schrade on 2016/1/10 20:09:49
Hard job (I/C) turned into an easy job.
Straight shot to A/C Programmer.
jpg  IMG_8016.JPG (946.13 KB)
1687_5692be6738841.jpg 2264X1698 px
Posted on: 2016/1/10 20:26
If all else fails, read FSM.
Can anyone tell what these pictures are of? WHERE of?
"Instrument panel left-hand sound insulator"
jpg  IMG_8017.JPG (844.13 KB)
1687_5692c3bf205b6.jpg 1815X1992 px
jpg  IMG_8018.JPG (969.07 KB)
1687_5692c4844e06c.jpg 2932X1710 px
jpg  IMG_8019.JPG (977.18 KB)
1687_5692c6349f98a.jpg 2590X1815 px
Posted on: 2016/1/10 21:00
My understanding is it is the "hush panel " (what I call it) that is above your knees. I thought you could remove the ac programmer without removing the dash. It should be against the firewall.
Posted on: 2016/1/10 21:25
You see it in post 1 pic?
Near the door? Or tranny tunnel?
Posted on: 2016/1/10 21:50
I think I found it.
I think somethin' else too - woulda' been easier to do a can opener through firewall.
Now - to remove, and test harness leads.......
jpg  IMG_8020.JPG (962.51 KB)
1687_5692d7b4f41d3.jpg 2264X1698 px
Posted on: 2016/1/10 22:14
More progress...
jpg  IMG_8021c.JPG (959.40 KB)
1687_5692ec03c49d6.jpg 2254X1691 px
Posted on: 2016/1/10 23:41
Now I'm going sideways (tomorrow), since another flow chart stopped me ALSO @ A/C Programmer, and since the test is NOT testing an individual circuit - step 2 here:
jpg  IMG_8023.JPG (975.73 KB)
1687_5692f0347e7af.jpg 1982X2121 px
Posted on: 2016/1/11 0:01
Not sure what that flowchart will tell you unless your blower motor runs all the time?
Posted on: 2016/1/11 4:27
Sure is Matt; I guess I didn't mention that?
Posted on: 2016/1/11 4:54
Add it to the list...lol. I guess all signs point to....
Posted on: 2016/1/11 15:13
Plugged everything in, except for Heater and A/C Programmer - from Step 2 post 61 above (Blower runs all the time).
Blower was Off.
next step...
... tomorrow.
edit:
Then again, turn it on, and listen to the fan come up, and start running.
Open in Circuit 65.
Damn!!!
Tonight, confirm that somewhere in diags for OTHER problems, there is a reference to fault in Circuit 65...........
Now I'm remembering that I didn't plug in the 2 'relays' [?], post #1. Damn.
Anyone know what those 2 devices are?
Posted on: 2016/1/14 22:29
Blower was Off.
next step...
... tomorrow.
edit:
Open in Circuit 65.
Damn!!!
That's the Bose and 2nd fuel pump relays (in pic post #1).
Uploaded from iPad - gettin' some youngin' learnin' in me!
jpeg  image.jpeg (223.45 KB)
1687_56994cce50fee.jpeg 960X720 px
Posted on: 2016/1/15 19:47
Alright - Chart 3 Blower runs all the time...
Step one pull A/C Head, result still running.
Says replace A/C Head Unit. So that would make Radio Head Unit inoperative???
Should be able to confirm by other symtoms' Flow Charts.
Posted on: 2016/1/15 20:46
In the earlier c4s the blower fan is almost always a bad blower control module. I know the fsm might say otherwise, but that's my research. Not to say that's your problem with all of the other symptoms you have.
Posted on: 2016/1/16 5:16
I wish SO MUCH that that was it Matt; but I'm about 99.9% certain not........
Now I'm stuck at Tech 1 use on ANOTHER Flow Chart.
Posted on: 2016/1/16 16:52
I'm stuck 2 Flow Charts for Tech 1 need.
So I decided to back it out, warm to Closed Loop, and bath.
EVERYTHING IS WORKING PERFECTLY, interior gutted D Side.
jpg  IMG_8110c.JPG (970.16 KB)
1687_569a8a5512eda.jpg 2264X1698 px
Posted on: 2016/1/16 18:22
And just noticed this:
REMAN UNIT!!!
jpg  IMG_8113c.JPG (889.46 KB)
1687_569aba16de890.jpg 2464X1848 px
Posted on: 2016/1/16 21:46
Fired it twice after soap & water.
Everything worked perfectly both times.
STILL doesn't tell me if I have a short / open lead, or if a device is intermittent.......
Posted on: 2016/1/17 1:02
Could be bad solder joints in the unit, just a thought.
Posted on: 2016/1/17 1:34
I'll have to gently ISOLATE the individual leads, and wiggle them. I HAVE seen the tranny selector lights flicker - probably something there.
Anyway, there IS ONE manifestation that I've had, since day 1 that I owned it - in the odometer. And I just saw yesterday the full problem in odometer, before it transitions to mileage.......
I don't know it this is related or not - it has remained constant in it's error, while I diagnose this new issue here.
When you first turn ON ignition, LCD lights up ALL segments in each digit.
2 of my digits are 'scrambled', as FSM calls it. First pic below.
Then, same digits are incomplete in mileage - second pic.
How many miles on my car? 3x,x44
Anyone with thoughts???????????
jpg  IMG_8116c.JPG (944.27 KB)
1687_569b1e80c3b84.jpg 2144X1608 px
jpg  IMG_0054.JPG (953.30 KB)
1687_569b20ccf0218.jpg 1736X1658 px
Posted on: 2016/1/17 5:05
If that's your only problem I'd say it's the LCD. If you have a lot of random dash problems the dash is fed from the CCM so I'd look there or grounds (which you already did).
Posted on: 2016/1/17 12:49
Fired again yesterday before plugging in the scanner, and again everything worked perfectly.
The scanner again showed the LED Dimmer Open or Shorted, as history...
Back in again...............................
Posted on: 2016/1/25 16:41
Anyone got a picture of 2 Grounds?
(ed.: 201 says, "Below LH Side of I/P, on LH Kick Panel, 202 says, "Below RH Side of I/P, on RH Kick Panel
I'm guessing the I/P is the WHOLE dash? )
Neither is illustrated in FSM...
jpg  IMG_8174.JPG (504.12 KB)
1687_56a6b48ebf400.jpg 3064X1120 px
Posted on: 2016/1/25 23:50
joeld Re: Help on CCM pull...
Can't help with a picture, but: I/P is instrument panel, also called "the dash panel"
Posted on: 2016/1/26 0:11
No pic offhand, my guess is each ground will be on either side of the footwell for the driver.
Posted on: 2016/1/26 3:28
Try this, Chuck:
Posted on: 2016/1/26 3:33
Yesterday, again, everything was in order again, except the chime for 'key in ignition, or lights on.
Today, all in order again.
Time to start wiggling harnesses, and re-connecting connectors, where accessible, with DE Grease...
Posted on: 2016/1/26 20:15
With key on Accessory, Radio was acting silly - antenna up, down, then Radio off, and it still played!!!
Posted on: 2016/1/26 20:42
New battery.
Clean, re-grease EVERY CONNECTOR while accessible.
Anyone know how to re-size iPad photos? Or change saved size? It's a pain re-sizing every photo to upload here, from camera card to computer...
Matt - you know what time limit is, to edit / add snappics to posts? I lose edit capability @ about an hour or so here ( got alarm set now ).
jpeg  image.jpeg (196.38 KB)
1687_56a7ec2be83e3.jpeg 960X720 px
Posted on: 2016/1/26 21:59
Edited by Schrade on 2016/1/26 22:16:39
Try again here... lost that one.
New battery.
jpg  IMG_8175c.JPG (907.59 KB)
1687_56a80068b52c9.jpg 1578X2104 px
Posted on: 2016/1/26 23:25
Break open, grease pins + seal.
What is this?
jpg  IMG_8176c.JPG (874.30 KB)
1687_56a8010379c31.jpg 2264X1698 px
Posted on: 2016/1/26 23:29
Tie all 8 junction straps together, order of removal...
and examination mounting stud.............................
jpg  IMG_8177c.JPG (882.65 KB)
1687_56a801bb581cd.jpg 2464X1848 px
jpg  IMG_8178c.JPG (860.76 KB)
1687_56a802215a6e8.jpg 2464X1848 px
Posted on: 2016/1/26 23:37
All 8 junction straps to B+ re-seated.
(MANY FLOW CHARTS REFERRED TO CIRCUIT 'X' TO B+, OPEN OR SHORT).
Relay, whatever it is - ANYONE??? , re-connected...
And a connector ground strap, straight from battery (-) post, cleaned and re-seated.
At the Yellow '?'; part of Airbag Circuit???
jpg  IMG_8182c.JPG (918.20 KB)
1687_56a91841bc1bf.jpg 2114X1586 px
jpg  IMG_8183c.JPG (913.66 KB)
1687_56a919da0d84a.jpg 2264X1698 px
Posted on: 2016/1/27 19:27
Cleaned, re-greased...
It LOOKED good before - but how many times do guys say that a ground 'LOOKED' good - P F F T T T. I didn't eat my carrots last night, so I cannot see those danged electrons...
jpg  IMG_8184c.JPG (908.17 KB)
1687_56a91b1d1016f.jpg 2464X1848 px
Posted on: 2016/1/27 19:32
Might want to read this thread about dielectric grease, some good info from BillH.
http://www.corvetteforum.guru/modules ... id=147280#forumpost147280
Posted on: 2016/1/27 20:35
I didn't see pro/con, on DE Grease there Joel...
But I put on a film every connector that I could get my hands on.
Anyway, I fired her with a new battery, + re-seated connections.
Spooled up fine, everything works - A/C, Radio, but I DO have to wiggle the key to get the 'Key In Ignition' chime to sound off.
Ignition Switch is stiff / sticky, in a way. Needs graphite / oil.
And now, ZERO LCD flicker.
BUT, bulbs NOW in left side of I/C (RPM's) are flickering. That's something I've done, since they didn't do that immediately after I/C re-assembly.
Hmm...
Posted on: 2016/1/27 21:26
So I'll have to pull the I/C again, double check connections there.
And, pull Ig. Switch cylinder, since that is dirty, fouled obviously... Does the wheel have to come off for IG Switch access???
Posted on: 2016/1/27 22:08
Yea, strg wheel has to be removed. Does car have air bags? If so then that adds a step also for coil removal.
Here's a picture to give you a good idea of the key tumbler location.
http://www.steeringcolumnservices.com/gmtilt.php
Posted on: 2016/1/27 22:26
Not much help in identifying your connectors, sorry.
For the ignition I would use a small amount of contact cleaner followed up with compressed air and then graphite to lubricate. No need to disassemble it.
Posted on: 2016/1/28 2:51
Old battery tested good. Not good; means weak current was NOT the problem...
Question now is, does LED Circuit go through Ig Switch? Even if it does, I think there's other bad connections...
LED flicker is GONE. But RPM bulbs flicker MIGHT be too much grease... AND, RPM needle is 'binding'. ???
Posted on: 2016/1/28 2:55
Fired up again, from Closed Loop the other day.
No codes.
Chimes for Lights On worked. As did Chimes for Key In Ignition.
Re-assembly is a pain, but no 'problem'. Breakdown for problem re-appearance is worse pain...
Posted on: 2016/1/30 20:24
Where is Ignition Switch in FSM?????
Got it; thanks........
Posted on: 2016/1/31 20:04
Instead of pulling Steering Wheel, I'm going to try to 'flush' Ig Switch.
Rags under column, and spray lube into Ig Switch, and work the key a few times.
I don't believe this will interfere with chip read.......
Posted on: 2016/1/31 20:20
Stuck the spray tube all the way into Ignition Switch, and let loose. Then worked the key On, Accessory, back and forth.
Then put shop vac to the switch, pulled out what excess that I could, vac down to column 'cuff', pulled more run-off.
Key in Ignition, NO chime. Spun up fine, chime OK for 'Lights On'.
Still listening, if anyone else is reading their own FSM's...
edit:
'Lights ON' chime now is fail.
Posted on: 2016/1/31 21:04
Alright - Flow Chart for fail Key in Ig Chime.
Step 1 - the lights DO come on.
Step 2:
What the hell is 'C'???????????
I know C1 - C16, and D1 - D16.
This test is obviously doing a by-pass. But where???
jpg  IMG_8202.JPG (701.21 KB)
1687_56ae830bf343d.jpg 1652X2116 px
jpg  IMG_8203.JPG (777.18 KB)
1687_56ae836b96f82.jpg 2364X1773 px
Posted on: 2016/1/31 21:58
Ok - text is necessary to post.
No text in post = corrupt content error
http://www.corvetteforum.guru/modules ... hp?topic_id=21136&forum=5
DAMN WTF IS GOIN ON???
jpg  IMG_8204.JPG (834.75 KB)
1687_56ae86f697f66.jpg 2464X1848 px
Posted on: 2016/1/31 22:13
« 1 (2) 3 4 »
