293 user(s) are online (45 user(s) are browsing Forums)
Ultraman, more...
Schrade Tech 1 in... LEARNING TIME!!!
More raw material for learning; and hardly scratched the MT-2500 capabilities...
Now this one (and it's NOT Tech 1A).
Anyone who's been here, SOUND OFF!
jpg  IMG_8310.JPG (988.15 KB)
1687_56d375e41ea52.jpg 1998X2664 px
Posted on: 2016/2/28 22:36
BrianCunningham Re: Tech 1 in... LEARNING TIME!!!
Serious hardware
Looking forward to reading your experience
Posted on: 2016/2/28 22:52
Schrade Re: Tech 1 in... LEARNING TIME!!!
Vehicle ID: (no 'Auxiliary' function cartridge inserted; only Primary)
This is pretty straight-forward...
jpg  IMG_8311.JPG (889.92 KB)
1687_56d38a65ea9a8.jpg 2264X1698 px
jpg  IMG_8313.JPG (841.09 KB)
1687_56d38ac1db5e6.jpg 2064X1548 px
jpg  IMG_8315.JPG (900.71 KB)
1687_56d38cd461fad.jpg 1788X1913 px
jpg  IMG_8316.JPG (937.57 KB)
1687_56d38d72d05eb.jpg 2064X1548 px
Posted on: 2016/2/29 0:15
VIN Select (ho hum)
And this is NOT ho hum. Hmmm........ A/C head Unit, and Radio Head Unit are OUT at the moment.
NO Check Engine Light, so............
jpg  IMG_8317.JPG (974.97 KB)
1687_56d38f93e42b0.jpg 1656X1877 px
jpg  IMG_8318.JPG (990.65 KB)
1687_56d38ffa26003.jpg 1668X1800 px
jpg  IMG_8319.JPG (922.70 KB)
1687_56d3903fba100.jpg 1916X1581 px
jpg  IMG_8320.JPG (978.95 KB)
1687_56d390cf874ac.jpg 2220X2124 px
Posted on: 2016/2/29 0:29
Now go to FSM 6E, and see that A/C, Radio Head Units out causes this. No big deal...
jpg  IMG_8321.JPG (957.14 KB)
1687_56d39234cc53b.jpg 2000X1588 px
Posted on: 2016/2/29 0:35
Matatk Re: Tech 1 in... LEARNING TIME!!!
22996 Posts
Looks like you are on your way. Not being a "1a" doesn't mean a thing.
You can do some cool stuff like monitor sensors/temps/idle counts/etc while the car is running.
You will also use it for the troubleshoot charts, as you already know.
Posted on: 2016/2/29 2:45
bogus Re: Tech 1 in... LEARNING TIME!!!
WOW!! Congrats!!!!
That is impressive!!!
Posted on: 2016/2/29 6:39
BillH Re: Tech 1 in... LEARNING TIME!!!
Looks like it's in really good condition too.
Posted on: 2016/2/29 15:08
Alright - I can't replicate the Diag Sys Check Fail (above) - I think I 'Entered' with key off...
...BECAUSE, I plugged in A/C and Radio Heads, and it won't replicate.
So I got navigation down pat [mostly] of the GM PRIMARY Cartridge 'GM 81-92 ECM'.
It has A/C function request check, and all responds accordingly, with A/C Head Unit controls.
(I did have
Now for more advanced checks - CCM Field and values, it appears I need to plug in Cartridge P/N 3000003. Quote:
MASS STORAGE CARTIDGE P/N 3000003 has everything in it I ... Power train, body control, etc
Where? Into Tech 1 Auxiliary port? Or Pull Primary Cartidge, and insert there???
Need help here guys...................
Matt - if I can make something of this, perhaps integrate this thread into 'Help on CCM Pull', re-title "Tech 1 / CCM Diagnostic"
jpg  IMG_8325.JPG (934.35 KB)
1687_56d4996810ca1.jpg 1698X2264 px
jpg  IMG_8326.JPG (854.61 KB)
1687_56d499ace3012.jpg 1698X2264 px
Posted on: 2016/2/29 19:22
replaces PRIMARY individual Tech 1 Cartridges???????
From Tech 1 / 1A User's Guide:
jpg  IMG_8327.JPG (968.04 KB)
1687_56d4a31ebcf5c.jpg 2234X1953 px
Posted on: 2016/2/29 20:00
This one SEEMS to indicate that 3000003 goes into MASTER slot.
jpg  IMG_8328.JPG (918.96 KB)
1687_56d4a74337e53.jpg 1777X2492 px
Posted on: 2016/2/29 20:17
22996 Posts
Replace the powertain cartridge with the mass storage cartridge. You will use the HVAC adapter in line where it plugs into the obdi port.
Posted on: 2016/2/29 21:08
Yes, it DOES go into MASTER.
I put it in Master slot, no mushroom cloud. Magic smoke that electronics work did NOT escape.
jpg  IMG_8330.JPG (967.61 KB)
1687_56d4b32e7b1e0.jpg 2264X1698 px
jpg  IMG_8331.JPG (899.00 KB)
1687_56d4b3944a023.jpg 1698X2264 px
jpg  IMG_8332.JPG (960.64 KB)
1687_56d4b3eac7b88.jpg 1623X2164 px
Posted on: 2016/2/29 21:11
Got a majority of navigation in this scanner down pat, including some test executions - Change Oil Light, A/C On and Off, Temp Control for ECC, Fan Speed; couldn't find ANY problems.
Disconnected it to go in and do some reading. Turned off Ig, and back on, and THE 3 DASHES ON A/C WERE LIT UP!!!
Went inside to get scanner, AND CATCH THIS THING IN THE ACT.
IT WAS DISPLAYING FINE; everything working perfect.
Posted on: 2016/3/1 17:28
22996 Posts
Intermittent problems are the worst!
Posted on: 2016/3/1 20:58
