187 user(s) are online (115 user(s) are browsing Forums)
Schrade Trim resto / paint...
Maybe photos n fun stuff; move accordingly.
Got them for < $30.
Before - D Side took a few hits here...
cleaned
Flat Black
taped off
jpg  sills.jpg (28.13 KB)
1687_578fbe29b0bfb.jpg 640X480 px
jpg  IMG_8669c.JPG (931.04 KB)
1687_578fbee93d3b9.jpg 2264X1698 px
jpg  IMG_8672c.JPG (958.93 KB)
1687_578fbfea50042.jpg 2134X1601 px
jpg  IMG_8673c.JPG (895.32 KB)
1687_578fc06985a92.jpg 2664X1998 px
Posted on: 2016/7/20 18:18
Schrade Re: Trim resto / paint...
Wet sanded w/ #800; drying.
(GENTLY sand - let the block ride atop the high spots first! )
Easy part over...
jpg  IMG_8674c.JPG (799.73 KB)
1687_578fc1359b48a.jpg 2364X1773 px
Posted on: 2016/7/20 18:22
GOLDCYLON Re: Trim resto / paint...
Peoria, Arizona
23 Posts
Looks great
Posted on: 2016/7/20 20:25
bogus Re: Trim resto / paint...
20878 Posts
sweet!!
Posted on: 2016/7/20 20:31
Peoria, Arizona
23 Posts
I'd go back with the white lettering
Posted on: 2016/7/20 21:28
NOT going well.
Unable to keep a 'plane' with the block sander, such that tape is leaving horizontal lines in lettering...
Additionally, adhesive is rolling onto lettering surface. Soap was necessary to stop this, and THAT's gonna' be a problem with outlying tape...
This might be futility exercise - calling for adhesive lettering.
Posted on: 2016/7/21 17:47
BillH Re: Trim resto / paint...
Schrade wrote:
NOT going well.
Unable to keep a 'plane' with the block sander, such that tape is leaving horizontal lines in lettering....
Can't quite get that in my head, You're having trouble keeping the block flat on the lettering?
The tape is leaving lines in the black paint before you paint the white?
Lines at the edge of the tape or where 2 pieces of tape meet?
And what kind of tape are you using?
Posted on: 2016/7/21 20:24
20878 Posts
you may be close to the answer...
instead of cutting letters, cut the vinyl to create the outline to paint the letters.
negative lettering, so to speak.
Posted on: 2016/7/21 22:07
As you can see, the Masking Tape has not sanded down to a perfect 'plane' (hard to see with remnants of original White; see the tape).
jpg  IMG_8680c.JPG (800.13 KB)
1687_5791530d51a05.jpg 2464X1848 px
Posted on: 2016/7/21 22:57
So you tried to sand the masking tape on the letters off?
First. kudos for trying something like that.
Secondly, you picked a rather hard to do project no matter how it's done.
I do some custom paint/graphics on cars.
I asked about that tape because it looks like regular Masking tape from Home Depot if so, the problems you had with the adhesive aren't surprising. I don't keep any of that tape in my shop and the blue tape at HomeD isn't much better.
Really, the only tape to use on projects like this is automotive masking, it's either green (3M) or orange, sometimes available at Walmart it the auto section. It's designed to not leave adhesive when pulled off.
And, in the pic, the tape is already pulling away in places.
But, as you know, taping these letters would be a bitch due to the rounded ends of the legs.
It would even be very hard to put tape on the letters and cut the tape with an Xacto knife though that's done on some custom work.
Personally, I'd try and hand pint the letters with 1Shot pin striping paint (because it lays down smooth) and a very good pin striping brush.
Where you are at now, I'd just shoot it the way it is now after sealing up the masking tape.
If you are still trying to get the adhesive off , don't use soap. The best would be Goo-Gone on a small rag with your finger and a wipe with plain water. You could also try lacquer thinner on the rag but that's iffy.
Posted on: 2016/7/22 0:44
BTW, here's some of my custom paint work, probably used a couple thousand feet of masking tape.
jpg  881_4953a0b767ab7.jpg (301.00 KB)
881_57916d3f034ee.jpg 886X598 px
jpg  r7.jpg (706.73 KB)
881_57916d596c4bd.jpg 2000X1695 px
Posted on: 2016/7/22 0:48
Ok - send a shipping address there Mr. H; take CC payment?
3M Tape - that's one thing I'm doin' wrong here; usin' budget masking tape. (and 3M has done me WELL for many years @ wall street)
I did use 3M masking on the plenum, and it sanded off very neatly, to leave tape in the conCAVE lettering. Can't remember anything conVEX I've done...
The adhesive isn't actually remaining; it's what's rolling up onto bare surface FROM the remaining tape, as I sand further. Wet sanding further, WITH soap, prevents this, but the soap also solves the tape. Soap wouldn't touch it if it was 3M tape. Gonna' try once more therewith...
jpg  IMG_5850.JPG (401.64 KB)
1687_57921db81a03d.jpg 2592X1944 px
jpg  HPIM7486g1.JPG (911.78 KB)
1687_579221c0f08bb.jpg 1876X1428 px
Posted on: 2016/7/22 13:38
Hell, I couldn't stand the frustration.
The standard 3m tape is just OK.
They do make a white automotive refinishing tape (under the Scotch brand).
You can get good automotive at an auto paint supply in your town.
https://www.amazon.com/3M-06652-Automo ... m+automotive+masking+tape
My local Walmart had the green 3m back by the Bondo in the automotive section. Them had switched to Rustoleum (orange) which is good but not as good as 3m, the last time I went in there.
On the cars, you figure that anytime you wet sand, you'll have to retape but the automotive tape will hold up much better than the standard tape.
The plenum looks great.
I go thru a lota tape.
jpg  2014-08-06 09-57-26_0001.JPG (583.56 KB)
881_57922da134087.jpg 1600X1200 px
Posted on: 2016/7/22 14:28
Need the blast cabinet for my guns.
What kind oscilloscope to right?
Posted on: 2016/7/22 22:32
You mean the white one to the right of the glassbead cabinet? Ha! That's a microwave oven.
That's my friend's shop, he has a new private paint booth.
The cabinet in that pic runs $2,200 with the vacuum attachment.
For smaller stuff, the one from Summit Racing or Harbor Freight works fine. I have the Summit, best damn thing I ever put in the shop.
However, the main expense for a blast cabinet is the air compressor.
The minimum you need is a 60 gallon, 3.75 horse (220v)
I looked for 6 months to find a used one and gave up.
I bought a Husky 60 gal at Home D. like this one:
11.5 cfm @ 90 psi
http://www.homedepot.com/p/Husky-60-G ... ompressor-C602H/205389936
It does keep up with my glass bead cabinet, runs air tools, spray guns.
At $490, it's a good investment for a shop. Mine's probably 7 years old and runs great (2ond best thing I bought for my shop). To go a step above this compressor would be at least 4x the price.
Posted on: 2016/7/22 23:31
j3studio Re: Trim resto / paint...
Looking good, everybody.
thumbup
Posted on: 2016/7/23 1:57
