295 user(s) are online (187 user(s) are browsing Forums)
CentralCoaster Aftermarket gas pedal mount...
So I finally broke my 32 yr old plastic pedal mount. Tried in vain to do a field repair and wasted a beautiful track day in the process, then drove home 2 hours with a piece of spaghetti under my foot.
Lo and behold the guru led me to this page: http://www.uniquecutting.com/products/
http://cdn2.bigcommerce.com/server900 ... 2347978.1280.1280.jpg?c=2
Crossing my fingers that he still has or makes them. I've had mine apart before, years ago for the last time someone tried to make one, but this guy has a design specific to the early cars.
Posted on: 2017/1/25 1:39
Matatk Re: Aftermarket gas pedal mount...
22985 Posts
This is the original thread I did when I beta tested the pedal from Bill at Unique Cutting. Very high quality piece and impressive craftsmanship. I hope he is still making them.
http://www.corvetteforum.guru/modules ... wtopic.php?topic_id=17843
Posted on: 2017/1/25 3:16
hcbph Re: Aftermarket gas pedal mount...
269 Posts
That is an impressive piece. Should outlive the body ;-)
Posted on: 2017/1/25 16:33
383tpimachine Re: Aftermarket gas pedal mount...
Corpus Christi
976 Posts
I have one. havent broken it yet.
Posted on: 2017/1/26 2:25
1970 El Camino-Awaiting LSX
CentralCoaster Re: Aftermarket gas pedal mount...
Yup, he had it in stock and I have it now. Finally a 1985 mount with proper dimensions.
As expected, same old slop due to wear on the pedal arm holes... The wear on mine while using a clevis pin over the past 5-6 years has oblonged them, with probably less than 10K miles on it.
But it'll do until I get around to upgrading the design. It has about 3/4" of slop side to side at the bottom of the pedal.
Posted on: 2017/1/30 21:09
bogus Re: Aftermarket gas pedal mount...
20881 Posts
I should consider one for my 92... it has a shit load of miles...
Posted on: 2017/1/31 21:50
