217 user(s) are online (47 user(s) are browsing Forums)
j3studio [Removing/Replacing Spark Plugs] What Tools Do You Prefer?
4246 Posts
[2003 LS1/A4 convertible, 52,000 miles, quite stock]
What tools do you prefer for removing/replacing spark plugs? I've been using a 5/8 spark plug socket plus four inch extension plus flex head ratchet and it hasn't been very effective. I'll freely grant that I'm not the most skilled wrencher (I managed to cut/abrade my hand with gloves on), so I'm looking for some suggestions on how to do this better.
Posted on: 2018/7/7 15:29
Ultraman Re: [Removing/Replacing Spark Plugs] What Tools Do You Prefer?
14723 Posts
That is basically the same set up I use......maybe a fixed head ratchet on some of the plugs will work better..... time and patience......each one is a victory.....
Posted on: 2018/7/7 17:01
j3studio Re: [Removing/Replacing Spark Plugs] What Tools Do You Prefer?
4246 Posts
Thanks, Marcus—I am surprised it is so hard …
Posted on: 2018/7/7 21:37
Matatk Re: [Removing/Replacing Spark Plugs] What Tools Do You Prefer?
22802 Posts
Personally, I only have one ratchet and one socket to do spark plugs
John, honestly I have all different types of ratchets, sockets, etc. My go to for most side-mounted plugs is a flex head ratchet and a swivel spark plug socket. For cars with limited access and/or headers, try a header spark plug socket with a flex head ratcheting wrench.
Hope that helps.
Posted on: 2018/7/8 3:08
4246 Posts
Hope that helps.
Thanks, Matt.
Posted on: 2018/7/8 14:54
14723 Posts
I seem to remember my L98 had a couple of plugs that were a real bitch to get out....... My LS3 is tight but not horrible........
Posted on: 2018/7/8 15:00
22802 Posts
John, this is a header socket:
https://www.summitracing.com/parts/sle-30102
Much shorter with a hollow center so it slips over the plug. Then turn it with an open end/box end/ratcheting wrench.
Before I knew they existed I made my own out of a regular spark plug socket that I cut down and drilled out. Easy to do.
Posted on: 2018/7/8 17:52
4246 Posts
Resized Image https://www.summitracing.com/parts/sle-30102
Much shorter with a hollow center so it slips over the plug. Then turn it with an open end/box end/ratcheting wrench. Before I knew they existed I made my own out of a regular spark plug socket that I cut down and drilled out. Easy to do.
Interesting … thank you!
Posted on: 2018/7/8 19:26
