BrianCunningham | Torque tube & clutches | ||
Saw Wheeler Dealers work on a C5 last week.
https://www.motortrendondemand.com/det ... rvette-c5-z06/0_p35cu91u/ I get removing the Torque tube to change the clutch I also get pulling the transaxle But dropping the entire rear cradle with the suspension to change a clutch??? Did they at least change this on the later cars? |
Posted on: 2018/11/15 0:51
teebee | Re: Torque tube & clutches | ||
I don't think so, Brian.
Posted on: 2018/11/15 3:14
2007 Atomic Orange 3LT coupe. Borla Exhaust One of Americas' proud Deplorable |
bogus | Re: Torque tube & clutches | ||
Nope...
it takes 4+ hours to bleed the clutch, cause you gotta get into the torque tube assembly... exhaust and that plate have to come down. There is a fix, but it will wait until I replace the clutch on my C6. |
Posted on: 2019/2/10 20:27
