261 user(s) are online (214 user(s) are browsing Forums)
istter1 Replacing suspected VATS / need key
Bakersfield Ca
2336 Posts
Can you use numbers off replacement VATS of where do you measure resistance for a new key
Thanks
Steve
Posted on: 2020/2/13 0:46
Carol Burnett
bogus Re: Replacing suspected VATS / need key
There is a little black thingy on the key... about 1/4" long... put a meter on both sides. That will give you a resistance number... then translate...
1 402 386 - 438
2 523 502 - 564
3 681 650 - 728
4 887 850 - 942
5 1130 1085 - 1195
6 1470 1411 - 1549
7 1870 1795 - 1965
8 2370 2275 - 2485
9 3010 2890 - 3150
10 3740 3590 - 3910
11 4750 4560 - 4960
12 6040 5798 - 6302
13 7500 7200 - 7820
14 9530 9149 - 9931
15 11800 11328 - 12292
Posted on: 2020/2/13 2:56
istter1 Re: Replacing suspected VATS / need key
Bakersfield Ca
2336 Posts
Andy my new used VATS does not respond to my old key. I assume I have to find what other code will let the system actuate.
Posted on: 2020/2/13 5:29
Carol Burnett
the key is most likely worn, or, the sensor inside the ignition is bad.
Using the key chip, get some resistors and match the resistance... then, under the dash, there are to very small wires with a small connector... jump them. I will research for more accuracy.
Posted on: 2020/2/13 16:31
Bakersfield Ca
2336 Posts
Just tested from back side of plug was easy new key made. Cranks but fuel pressure not holding . Will pressure test lines this weekend.
jpg  IMG_1835.JPG (82.30 KB)
5144_5e461a59c733f.jpg 640X480 px
jpg  IMG_1834.jpg (69.84 KB)
5144_5e461a67047ee.jpg 640X480 px
jpg  IMG_1749-2.jpg (107.77 KB)
5144_5e461afeb801c.jpg 640X480 px
jpg  IMG_1748.jpg (113.07 KB)
5144_5e461b12c2aec.jpg 640X480 px
jpg  60116002490__CFC324A7-F2A7-411B-BF84-3CC9EAB1C6EE.JPG (135.79 KB)
5144_5e461b29d8aea.jpg 640X480 px
jpg  60115985426__1CFE58BA-E06A-4510-A135-464CB4AE7EAB.JPG (139.82 KB)
5144_5e461b4a0171c.jpg 640X480 px
Posted on: 2020/2/14 4:00
Carol Burnett
Check valve... common failure point.
I gave up on junk pumps and bought one from Racetronix... really nice part.
Posted on: 2020/2/14 19:10
Bakersfield Ca
2336 Posts
The one my son remove was from Racingtronics . I will find what is causing the pressure loss if in have to replace every fuel line.
Posted on: 2020/2/15 2:23
Carol Burnett
If you had a real leak, there would be stink... check the injectors, too.
I would bet on the check valve in the pump.
Posted on: 2020/2/15 21:53
Bakersfield Ca
2336 Posts
All leaks repaired
jpg  IMG_1852.jpg (106.14 KB)
5144_5e4b369900a88.jpg 640X480 px
Posted on: 2020/2/18 0:48
Carol Burnett
