CorvetteBob | Fuel lines, which is which? | ||
In working on my fuel system over the past several months, I seem to have forgotten which outlet at the top of the tank is the pressure line, and the return line.
I’ve tried to add a pic but I can’t get one to go. My pics are too big. |
Posted on: 2020/11/5 22:31
Matatk | Re: Fuel lines, which is which? | ||
Not my pics, but might help. It's been a while but I think the FSM has the info. I'll try to check later.
Posted on: 2020/11/6 0:06
joeld | Re: Fuel lines, which is which? | ||
In Matt's pictures the top hose with the two clamps is the feed(pressure) and the bottom hose is return. The hose on the left is vapor return.
Joel |
Posted on: 2020/11/6 0:11
1989 Coupe,L98 automatic |
CorvetteBob | Re: Fuel lines, which is which? | ||
Thanks Joel.
That’s kind of what I thought, but needed to find out just to make sure. |
Posted on: 2020/11/6 0:37
I’m also trying to figure out where this very short ground wire should attach.
It’s length would say attach to a screw on the tank unit, but something about that seems odd. Racetronix has been no help, I’ve called twice. Again, I’m trying to add photos but my iPhone 7+ isn’t cooperating |
Posted on: 2020/11/6 16:45
I'm not sure what ground wire you're referring to.
The forum doesn't accept pictures over 1000k. You'll need to use a photo resizer program to reduce the size before you can upload them. |
Posted on: 2020/11/7 5:51
Yeah. I tried a couple apps with no luck. If you have time, send me an email to bobzcarz@yahoo.com and I’ll attempt to send you the photo of the wire in question
Posted on: 2020/11/7 23:44
It’s been a couple weeks and I still haven’t really come to a firm conclusion. So I’m just gonna overkill it. I’ll put the connector to a gear clamp, and further run an additional length to a ring connector and finish at a hold down screw for the tank unit. I might even bare that wire and pass it under the line clamps for static. But even I think it’s too much.
Posted on: 2020/11/18 22:50
