316 user(s) are online (290 user(s) are browsing Forums)
CorvetteBob Fuel lines, which is which?
1409 Posts
In working on my fuel system over the past several months, I seem to have forgotten which outlet at the top of the tank is the pressure line, and the return line.
I’ve tried to add a pic but I can’t get one to go. My pics are too big.
Posted on: 2020/11/5 22:31
Matatk Re: Fuel lines, which is which?
22803 Posts
Not my pics, but might help. It's been a while but I think the FSM has the info. I'll try to check later.
jpeg  DSC01589.jpeg (29.74 KB)
994_5fa4935b716d9.jpeg 512X384 px
jpg  20140618_113041.jpg (78.42 KB)
994_5fa49365680a9.jpg 800X600 px
Posted on: 2020/11/6 0:06
joeld Re: Fuel lines, which is which?
In Matt's pictures the top hose with the two clamps is the feed(pressure) and the bottom hose is return. The hose on the left is vapor return.
Posted on: 2020/11/6 0:11
CorvetteBob Re: Fuel lines, which is which?
1409 Posts
Thanks Joel.
That’s kind of what I thought, but needed to find out just to make sure.
Posted on: 2020/11/6 0:37
1409 Posts
I’m also trying to figure out where this very short ground wire should attach.
It’s length would say attach to a screw on the tank unit, but something about that seems odd. Racetronix has been no help, I’ve called twice.
Again, I’m trying to add photos but my iPhone 7+ isn’t cooperating
Posted on: 2020/11/6 16:45
22803 Posts
I'm not sure what ground wire you're referring to.
The forum doesn't accept pictures over 1000k. You'll need to use a photo resizer program to reduce the size before you can upload them.
Posted on: 2020/11/7 5:51
1409 Posts
Yeah. I tried a couple apps with no luck. If you have time, send me an email to bobzcarz@yahoo.com and I’ll attempt to send you the photo of the wire in question
Posted on: 2020/11/7 23:44
1409 Posts
It’s been a couple weeks and I still haven’t really come to a firm conclusion. So I’m just gonna overkill it. I’ll put the connector to a gear clamp, and further run an additional length to a ring connector and finish at a hold down screw for the tank unit. I might even bare that wire and pass it under the line clamps for static. But even I think it’s too much.
Posted on: 2020/11/18 22:50
