208 user(s) are online (182 user(s) are browsing Forums)
Sheet Molded Compound.
The onl...
Ramrod C-4 Tech Needed, 40 Codes
S. California
296 Posts
1996 LT-1 can't pass smog certification, 2 "H" codes on the dash and 40 codes on my Zurich ZR 13 reader??? Any reputable C-4 techs in the 91763??
Posted on: 2021/5/13 20:18
1996 LT-1
DynaSpark Opti, Tapered Rear Wheel Bearings, SS Brake Lines, Speed Bleeders, MC Bias Spring, Hawk HPS Pads, MSD Wires,NGK Iridium, lowered, etc.
Matatk Re: C-4 Tech Needed, 40 Codes
22803 Posts
40 codes seems excessive. What are they? Could be an issue with the code reader. Was the battery dead recently? I'd clear the codes and see what comes back.
Posted on: 2021/5/14 0:21
bogus Re: C-4 Tech Needed, 40 Codes
40 codes would imply a bad PCM... if it was true.
Reset and retest... and if you can, list the codes. The codes themselves are the value, not a vague "I have codes, what do they mean" comment.
Posted on: 2021/5/14 14:41
Ramrod Re: C-4 Tech Needed, 40 Codes
S. California
296 Posts
Zurich ZR-13 reader Chevrolet OEM Enhanced, 40 DTC
P0100-(1/40)
https://www.dmv.de.gov/VehicleServices ... ections/pdfs/dtc_list.pdf
The 1-40 codes are listed on my reader, most conflict with another, high voltage vs low voltage, high temp vs low temp etc. I suspected a bad PCM or a bad ground? Long story longer I took it to a reputable mechanic in Claremont, Ca for smog certification, they recommended new injectors I said OK. About 4 days and $$$$ they can't figure it out and suggest I throw more parts at it to fix and still no smog certification.
Posted on: 2021/5/15 19:04
1996 LT-1
well.... stop spending money.
1. test the alternator
2. what injectors did you get?
3. check grounds - the battery ground to chassis will corrode
4. check battery terminals
5. test the battery
Posted on: 2021/5/16 15:48
oh, how many miles?
Posted on: 2021/5/16 15:53
S. California
296 Posts
Ill give it a shot, im heading out for a few days and get on it then. Thanks for the suggestions.
Posted on: 2021/5/16 18:19
1996 LT-1
S. California
296 Posts
one hundred and twenty thousand
Posted on: 2021/5/16 18:21
1996 LT-1
120k... check grounds around the battery.
These cannot be "real" codes, if so, the engine would run like absolute garbage.
Posted on: 2021/5/22 16:01
