joesroad | Cooling Fan Relay | ||
Can anyone tell me where the relays are located for the cooling fans on a 1988 coupe? The fan in front of the radiator is not coming on even with the a/c running so I quess its time to try track down the problem.
Posted on: 2007/2/21 0:58
bogus | RE:Cooling Fan Relay | ||
them damned things!
they move around, no question about that. In some years, they are on the inner fender... on others, they are down next to the radiator, to the left of the radiator, near where the support strut is for the hood. also, chase all the wiring back, and confirm nothing is broken. wiring in pre-1990 Vette's is suspect at best. |
Posted on: 2007/2/21 2:58
freakd | RE:Cooling Fan Relay | ||
should be on the left hand side, right behind the wheel well :thumbright:
Posted on: 2007/2/21 20:02
joesroad | RE:Cooling Fan Relay | ||
Thats it, thanks for the help.
Posted on: 2007/2/21 21:55
