243 user(s) are online (198 user(s) are browsing Forums)
 Topic is Locked
jsup Transmission questions, PETE!!!! YOU AROUND?
1778 Posts
So now that I'll be a bit more comfortable that the motor is coming together, I am starting to get concerned about the transmission.
It's not a question of IF, it's a question of when.
Even with this partial tune, the car buzzes up like a two stroke engine with the pedal 1/2 way down. Pops straight to 6500 RPMs.
Anyway, I want to start understanding what to do for a trans when it's time, so when it goes, I can jump right on it and have a plan of action already written.
Here's a local place I may shop at tomorrow:
http://www.importperformancetrans.com/gmautorwd.shtml
Anyone know them? Pete is this a good deal? Check out their 700R? Are they suing the right parts?
Pete, would you be willing, do you have the time, to do one for me?
I guess my question is, what do I need to look for in a transmission that can handle the HP/TQ my motor puts out. Particular parts or components?
I know 600 may be a bit of an exaggeration, however, for arguments sake, lets shoot for a trans that can handle REAL HP, in the 750 ish range. I prefer to have some over head. In case I decide to go spray in the future, or switch some parts to pick up the power I'm leaving on the table.....
Posted on: 2008/10/22 1:18
bogus Re: Transmission questions, PETE!!!! YOU AROUND?
tko 600
Posted on: 2008/10/22 4:38
jsup Re: Transmission questions, PETE!!!! YOU AROUND?
1778 Posts
tko 600
???? Can you explain? Link? Foreign to me.
I googled it a manual comes up.
Posted on: 2008/10/22 12:35
1778 Posts
OK PETE!!!! I'M DESPERATE, JUST LOST THE TRANS TODAY! TAKE THE VET TO WORK DAY WAS A FAILURE!!!
HELP!!!!
Posted on: 2008/10/22 16:36
biggrizzly Re: Transmission questions, PETE!!!! YOU AROUND?
Same situation here but not as bad! Mine is just slipping when I get on it hard then it catches and scoots!!
But its still pretty mushy all over. I need to get it rebuilt and install that nice new converter Pete had built for me.
Did yours leave you stranded or did it limp back home with its tail between its legs?
I knew this would probably happen to mine, but I figured it would last a bit longer.
Posted on: 2008/10/22 18:08
1778 Posts
Well, I'm sitting at work, about 10 miles to home.....so I'll drive it home tonight and go from there.
This guy is by you, do you know anything about him?
I don't.
http://awesomeengines.biz/
Came recommended from someone.
Posted on: 2008/10/22 18:11
I don't.
He's in Delaware. Selbyville is a few hours from here, but I never heard of him. The Chesapeake Bay proves to separate us quite a bit from the eastern shore of Maryland and DE.
I haven't really started looking yet, but I have a couple local goons that rebuild them all the time with stock components for cheap. I have thought about asking them to rebuild mine with parts from Petes list. The one guy said he'd do mine for $600 I supply the parts I want. I'm not sure how good he is, except he rebuilds a ton of regular daily driver trannys each and every day. So its not like he doesn't know how they go together.
I'm kind of scared to go to him because I don't know anything about him and he doesn't do any racing applications, just daily drivers for the regular Joe off the street that needs a cheap trans rebuild.
Posted on: 2008/10/22 18:28
1778 Posts
I don't.
Here's the issue, from what I understand is that if you don't build it RIGHT the same thing will happen. I am researching and hearing stories of trans lasting 3-4 months after a stock rebuild.
The issue is, do you want to do it cheap? Or do it over?
One shop I just talked to said order a TCI from summit and be done with it, they are a good trans, they are $1500.
IDK if that's true, I have to run it past Pete and see what he thinks.
He charges $500 to put it in, so I'm in it for $2K done.
Just a thought.
Posted on: 2008/10/22 18:32
The TKO600 is the manual transmission conversion from Keisler. "600" refers to the torque handling ability.
Otherwise, a TH400 with a GVOD would kick ass.
Posted on: 2008/10/22 18:38
1778 Posts
Those are pricey aren't they?
Posted on: 2008/10/22 19:23
Just a thought.
From my conversations with Pete, I think he will nix the TCI thought. I don't think he thinks too much of thier transmissions.
Posted on: 2008/10/22 19:26
compared to a 700R4.... maybe.
The TKO600 is about a $3k kit.
The TH400/GVOD... gee... not much change from $4k. That's pricy.
Posted on: 2008/10/22 19:30
What about these guys - looks interesting
https://www.700r4l60e.com/store/home.php?cat=18
Posted on: 2008/10/22 19:56
1778 Posts
OOOOOHHHHH SHIT!!!
I have a problem.
Look what I found! Scroll to the bottom.
http://www.transmissioncenter.net/4L60E_to_4L80E_Swap.htm
$5500 for the trans guaranteed to 1000 HP...
I best loose that page.....maybe I'll save my nickles till spring for this one.
I know for sure if I do this, I will NEVER have another problem.
Posted on: 2008/10/22 20:15
I think the T-Shirt sold me!!!
I'm considering doing this whole rebuild myself! I've been looking at those turn-key kits and they have all the parts that PeteK has on his list. Maybe Pete can do a better package?
Anyhow - I'm not afraid of tearing into it, I just need time and motivation again!
Posted on: 2008/10/22 20:27
1778 Posts
That's funny!!!
Posted on: 2008/10/22 20:51
the 4L80E... do you all know what that is???
Essentially, a TH400 with an OD unit and locking torque converter.
Now... if you can get the Allison in there... damn... but that ain't happening. That box is the size of a damned beer keg.
Posted on: 2008/10/22 21:26
1778 Posts
ok, that 480 is steep
I'm looking at this guy:
http://selecttransmissions.com/index.html
hey came VERY HIGHLY RECOMMENDED anyone know anything about them?
Posted on: 2008/10/22 21:49
pr0zac Re: Transmission questions, PETE!!!! YOU AROUND?
i have heard good things about bowtie overdrives and chp.
Posted on: 2008/10/22 21:55
1778 Posts
They aren't local, I'm hoping to find someone relatively local and reputable so I can kick their ass if it breaks..
Posted on: 2008/10/22 22:00
honestly i wouldn't buy a tranny from a local guy. they really don't have the knowledge to build a 700r4 that will handle what you want. i tried doing the same and just don't feel like they know the tranny's weak points and secrets to making them last.
Posted on: 2008/10/22 22:17
1778 Posts
Did you see the link I put up? The guy has been in business over 20 years, and builds racing transmissions.
He did come highly recommended....
Not saying he's great, just sayin'....
I am fairly certain another 700 will fail again.....so I prefer it be local.
Posted on: 2008/10/22 22:46
match that up to the internals on big names like performabuilt(http://www.performabuilt.com), CHP(http://www.cahallperformancetransmissions.com) or Monster(http://www.eatmyshift.com). then make your decision.
Posted on: 2008/10/22 23:20
1778 Posts
I spoke to Pete, he's going to be my transmission lawyer
he's going to look at my options and give me advice before I do anything.
Posted on: 2008/10/22 23:41
PeteK Re: Transmission questions, PETE!!!! YOU AROUND?
John,
Glad to hear from you today, but wish it was under better circumstances. I will try to post everything here, so others can benefit from it as well.
I wish my new job did not destroy my free time, or I would build your trans for parts price only. It would make a great R&D trans.
I do have a few transmissions running around that are working well behind similar combo's. I humbly say that I have built a few that have been very good. The key is blueprinting, moreso than parts selection. Although both are important.
Until I can offer up a complete parts list, I wanted to offer the following:
1)Never under estimate the benefit of dealing with someone local, that is qualified. If they have pride, and attention to detail, they can do it. Something to be said about doing handshake deals.
2)Mailorder is fine, but if you have a problem, it is difficult to resolve in a cost effective manner. I personally have never been a fan of mailorder. I have reaped the benefits of it, that is true, but never really understood the nature of such a purchase.
3) Forget warrantees. Realisticly, no one will offer one, and those that do will often find a reason to deny a claim. It is human nature, and fair under the circumstances (big powered auto.
4) The best builder is one that is enthusiastic about the build.
I have had too many mixed drinks to offer much else this evening,
but shall follow through as promised.
Find a good builder and roll the dice.
Should be a fun project that hopefully does not break the bank.
Posted on: 2008/10/23 1:37
1778 Posts
http://www.performabuilt.com/GMCars032008.html
OK, it's 11:45 at night and this guy gets on the PC with me in IM chat.
His trans comes with a 1 year warranty but is pricey, $2600. for $2300 I can get a 6 month warranty.
He has layaway, which I can leverage to not pay him if the trans fails..
Plus, he's willing to put in writing that he'll give me a year for the 6 month price, or start the 6 month warranty next season, he's willing to work with me.
He had a conversation with me at 11:30 at night.
He's only 2 hours away or so...
Now, does this make him good, or desperate?
IDK, PETE, ever hear of this guy? Any good?
Hey, BG ,want me to ask about a two trans discount? He seems rather flexible...
Posted on: 2008/10/23 3:55
That company is located 20 miles from my home in Pennsylvania. I do know know if they have a local reputation, as I never heard of them until I found them on the internet.
I do know that they are active on the following websites:
Thirdgen.org
camaroz28.com
corvette forum (occasionally) user name pba
ebay
I have heard nothing negative at all about them.
Posted on: 2008/10/23 20:00
i will tell you i have dealt with them and they will make a situation right.
Posted on: 2008/10/23 22:53
1778 Posts
Who did you deal with there? Frank?
Posted on: 2008/10/23 23:08
I'd be interested in seeing what he'd offer. I have been to his website before. I would only need his level 1 transmission that is good up to 500hp.
There was one of the Level 3 Super Heavy Duty ones for sale on our local Craig's list just a couple weeks ago. It was brand new never installed.
Posted on: 2008/10/24 0:23
1778 Posts
really? For a couple bucks I'd go stage II, I'm looking stage III
I'll ask the question.
Posted on: 2008/10/24 2:20
Livin_the_dream Re: Transmission questions, PETE!!!! YOU AROUND?
robesonia , pa
516 Posts
I haven't posted in any of your posts on here or the other forums on since the "I'm this close to giving up" thread. Instead I have just sat back and lurked. My response which you blew off as I'll fix it when it breaks was this. I suggested that with all your new horsepower you better look at your tranny. I mean after all with the motor out its nothing to pull it.You have not had the car running long and already you need your tranny rebuilt. hate to say I told you so but...
Posted on: 2008/10/24 3:00
1778 Posts
So, it broke, and I'll fix it.
BFD.
I'm not surprised
I expected it, just happened a little sooner than I had hoped. Again, BFD.
I didn't blow it off, but I had a choice to make. I had so much money to spend and a tranny could not be justified to the wife until it blew up. Period. I never argued that it would, go back and check my posts.
My tact is to finish the engine and cross my fingers, or do what so many people do and start collecting all the really cool parts and never get anything done. That's how many builds stall at the bench.
Posted on: 2008/10/24 3:20
I'd have to agree with John on this one too! I was in the same situation where I had just enough money to get the damn thing running.
I have a brand new set of ring and pinion and a PeteK converter sitting on the shelf in my garage because I knew I would need those later, I just couldn't do everything at the moment. It has to be a little at a time or it ain't gonna happen in this lifetime.
I could have just let it all sit until I had the money to do the whole project but it would have been at least another six to twelve months and I wanted to get the car on the road. I'm gonna do the transmission first, and then even later go back under and do the rear. I know that while the transmission is out the rear should be done to save time, but its not the time, but the money.
If only I didn't have other stuff to take care of like a big mortgage and food and stuff I'd get the whole thing done turn-key by a big fancy corvette shop and just wait until it was done,,, hee hee!
Take Care
Posted on: 2008/10/24 3:35
1778 Posts
Oh yeah, and I'll call it now.....I MAY lose the rear too. Less likely than the trans, but a possibility. Some D36s last forever under abuse, some blow up, luck of the draw I suspect.
Posted on: 2008/10/24 3:42
Schrade Re: Transmission questions, PETE!!!! YOU AROUND?
My '02 1-ton had 4L80e tow package 3500 stall. Bought new, still pulled like a champ at 195k when I gave it up. Didn't flinch with over 3250 lbs paper in back. MANY times...
Posted on: 2008/10/24 4:48
you want a cookie? for real? its not like he didn't know if it were going to happen. shit happens.
Posted on: 2008/10/24 20:43
dan0617 Re: Transmission questions, PETE!!!! YOU AROUND?
JSUP, I think I'll be in the same boat eventually. For now my stock trans is surviving. I wonder if the TCI constant pressure valve body would help a stock trans survive? I heard higher line pressure would help keep slippage from starting. Anyone on here know if that is true? If so, I might try one. Would be nice to raise the part throttle shift points some too! Supposedly this valvebody will allow you to do that. Should be nice in even in an aftermarket or rebuilt 700r4.
Posted on: 2008/10/25 15:59
1778 Posts
Yeah, it's for real. Sounds like something I'd hear on another place on the internet....
Posted on: 2008/10/25 16:16
1778 Posts
So BG, here's the story.
I have checked with people who have done business with Performabuilt. Can't find anything bad about them.
the deal is the stage III for my car would run $2400 with a 6 month Warranty. Better than others I can find.
The kick in the ass is that even after the warranty runs out, if the trans ever breaks, repair costs, including shipping is $975 as long as you own the car. Seems reasonable and more than other people are offering.
So I'm giving these guys some serious consideration, but still shopping around.
Posted on: 2008/10/25 16:22
John,
As I mentioned on the phone, we had a similar motor in my friends 92 formula. By coincidence, we found a 92 trans in the boneyard, as it was formally a stick car.We used a B&M transpak shift kit. My buddy pounded the dick out of that car, for over 2 years, then sold it to a streetracer near Atco, NJ. I uderstand that it is still running well, after approx 4 years.
The recipe was:
Pump:
Stock 10 vane gm (new vanes)
.471 boost valve (stock vette)
.283 lo-rev boost valve (stock vette)
Transgo no yo yo kit (high rpm spring and hardened vanes)
1 pc 93 and up style stator sealing rings
Wide rear stator bushing.
Teflon front bushing
B&M regulator spring from shift kit
Reverse drum:
Borg worner frictions
orifice plug for aluminum piston
.050 clearance
Kevlar band
Servo:
Stock vette
.085-.090 pin travel
Input Drum:
1 pc sealing rings
BW frictions in forwards, and overruns
29 element BW sprag
Raybestos Z-Pack with matching GM apply ring (set to .050)
98 and up steel apply pistons
Transgo High rev return springs.
Stock Gm 4 pinion planetaries
Beast reaction shell
2001 and up rollerized stator shaft and bushing
Sonnax wide bushing in rear sun gear
Lo Roller:
BW replacement element
BW frictions set to stock stack height
New governor gear
Rear teflon tailhouse bushing
New accumulator pistons
White spring in aux valve body
NEW seperator plate. GM is discontinued for 1987, so a transgo plate will work well.
Valvebody modded as per B&M
New 4th pressure switch
New 4-3 pulse switch
New lock up solenoid
Others may agree or disagree, but this combo has worked well for my on high powered stuff with hard 60' times
Posted on: 2008/10/25 16:25
robesonia , pa
516 Posts
BFD.
I'm not surprised
I meant you blew me and my suggestion off. AS with anything car related the odds of never getting anything done or getting it put back together are pretty high and we get parts vehicles.
I'll also concede that just like politics all of us have different ideas about how to do a build. Me I go for reliability as I like to go for long weekend drives. Maybe it takes me a little longer to complete. I do my projects over the winter so time is not the important thing to me reliability is.
As far as the rear ,labor wise its nothing compared to pulling the tranny when the motor was out.It could be done at any stage and still require the same amount of labor
Although I don't have to justify anything , she knew my car vice when she met me. She also knows that I like to do things once and be done.She also like to travel with me in the car and wants it to be reliable as well
Guess I'll go back to reading your threads , shaking my head and agree to disagree with you
Posted on: 2008/10/25 16:28
I provided the list in the event you use a local trans shop.
PBA may agree or disagree with my recipe, and since they do it for a living, they should build something better than I could.
Warrantee sounds very good also.
1778 Posts
Hey Pete, they list all the parts they use here:
it's this:
http://www.performabuilt.com/GMCars022008.html
Plus this:
What do you think?
Posted on: 2008/10/25 19:47
it's this:
Plus this:
What do you think?
It is very similar to my build, but with a bit more "bling"
5 pinion planetaries are not nescessary, and neither is the servo. Money added to the budget not needed, in my opinion.
I would never use a 13 vane pump. I have never had a 10 vane failure, but have seen many 13 vanes pop.
Posted on: 2008/10/25 19:56
1778 Posts
it's this:
Plus this:
What do you think?
So basically you're ok with it outside the 13 vane pump and planetaries? I'll ask to ramp them back and see if I can save some money.
And yeah, the warranty seems pretty good.
Posted on: 2008/10/25 20:55
I personally would not run the 13 vane pump in anything, including a 6 cyl daily driver. The 5 pinion GM planetaries are fine. Overkill, but fine. If he requires them for the warrantee, no harm or foul, just lightens the wallet a bit.
Aftermarket 5 pinion planets are junk with a capital J.
Avoid them at all costs.
Posted on: 2008/10/25 21:07
1778 Posts
cool. thanks
I am trying to learn what I can, I'm thinking that since the car will be stored for the winter, I can save some money over the winter and do this in april.
Posted on: 2008/10/25 21:15
Guest_
I myself would go to the GN site's, and see what they use. Go see how they beefed up there 200R4 to take over 800 hp.
Posted on: 2008/10/26 11:26
1778 Posts
who is GN and can I get a link?
Posted on: 2008/10/26 14:37
 Topic is Locked
