302 user(s) are online (276 user(s) are browsing Forums)
wesmigletz Another trip to the track
Land of Fruits and Nuts
325 Posts
Drove the 62 back to Famoso (another 250 miles round trip) this past weekend for the ANRA (American Nostalgia Racing Association) finals. Before heading to the track on Friday, I replaced the low-rise Weiand 8120 dual plane intake with a ported #7530 Team G intake. The Team G is opened to a 1206 gasket, but my heads are not, so it was less than ideal.
The Team G intake fit under hood with a GM drop base air cleaner. I do not think it would clear with an aftermarket drop base, because they offer less drop than the GM piece.
Driveability isn't bad with the single plane, but I did notice the need for more throttle going up the Tejon Pass. I would really like to try the #8120 intake with some port work and a notched divider. The Team G picked-up a few hundredths in the quarter, and gained a few hundredths MPH over the low-rise dual plane.
All passes were made with 38* timing and 73 primary and 82 secondary jets. My son did his first solo jet change upon our arrival to the track on Saturday.
My best pass was 12.77 @ 107.39, with a 1.78 60’ and 8.145 @ 83.45 in the 1/8th mile.
My best MPH was 108.00 @ 12.795, with a 1.829 60’, and 8.185 @ 83.75 in the 1/8th mile.
The car ran consistent, and I did well during eliminations, until I was told I had to dial back to 13.50 because of the soft top. I wasn’t thrilled about it to say the least. Just for spite, I went 13.55 on a 13.50 dial in on my next pass, sending a rather clean El Camino home. Pure luck on my timing to lift. I was eliminated the next round. I waited too long to lift and ran 12.97 @ 94 MPH. It’s too bad because the other guy broke-out too. Coulda woulda shoulda, I think I could have made it to the finals if I didn’t have to change my dial-in…
Some other pics are posted here:
http://www.picturetrail.com/sfx/album/view/12432617
Posted on: 2008/10/29 5:19
cuisinartvette Re: Another trip to the track
Did you make any jetting changes for the larger intake?
Nice to see youre down in the 12s.
Posted on: 2008/10/29 5:52
wesmigletz Re: Another trip to the track
325 Posts
I drove to the track with 69s in the primaries. I had Reb swap in the #73 jets when we got to the track. I ran 74s in the primaries with the low-rise dual plane.
I did not make additional changes because I wanted to work on the cars consistency for qualifications and eliminations. I was also thinking the the single plane should need less jet than the dual plane, because the plenum saw all for barrels, whereas the dual plane limits each port to only two barrels.
I need to get my LM-1 on the car and start using it...
Posted on: 2008/10/29 6:15
Matatk Re: Another trip to the track
22803 Posts
Well it sounds like those are good results considering you thought you'd lose time and mph. Is it due to the port work? Will you be porting or swapping the heads? I thought I read something about AFRs?
Keep us posted.
Posted on: 2008/10/29 11:59
sccavette Re: Another trip to the track
Kokomo Indiana
39 Posts
to you for using the C1 and not letting it sit in the garage and just look pretty.
I would love to see a C1 race at out local strip.
Posted on: 2008/10/29 12:51
325 Posts
Matatk wrote:
Well it sounds like those are good results considering you thought you'd lose time and mph. Is it due to the port work? Will you be porting or swapping the heads? I thought I read something about AFRs? Keep us posted. Matthew
Matatk, I did expect to lose ET and possibly even MPH. The opposite happened. I suspect it was due to the low-rise dual plane simply having too small of a plenum, not so much the porting. If I had the $$$, I'd like to extrude hone the intake and notch the plenum divider similar to an RPM. That would probably pick me up .1 - .15 seconds in the 1/4. I also think if I spent some time on a chassis dyno with my LM-1 and timing light, I could find another 10-20 HP, and if I leaned my IFRs, I might pick-up some economy too.
Intake port on head vs intake mismatch (1206 gasket)
I'm going to be pulling the engine this weekend. I'll be swapping to a HR cam with similar specs and getting some dyno numbers. Hopefully it picks-up HP and torque without costing me idle vacuum. From there, I will also be doing an A-B head swap on the dyno. The engine will be going back in the car and back to the track. At that point, I will no longer have just an opininon, I will have dyno numbers from the same dyno same day, and time slips.
From there, who knows, I may swap my stock heads back on (if the HR cam picked up HP and torque). I'd like to have my stock, cast iron intake fully ported, and I'd clean-up a set of 2.5" rams horn manifolds. I'd like to see if I could dip back into the 12s with the stock engine (block, heads, intake, carb, and ex manifolds). Considering our car is a low-horse, automatic "secretary's" car, I think it would be fun to do.
Posted on: 2008/10/29 15:06
325 Posts
Well, I'm just a driver, not an enthusiast. I have no idea what owning a classic Corvette is all about, nor do I have an appreciation of their history... according to a couple real Corvette enthusiasts I've run into.
Being just a driver, I drive the car often. In fact, we put over 500 miles on it over the past two weekends going to and from the races.
Glad to see you're out enjoying yours too.
Wes
Posted on: 2008/10/29 15:10
Sounds like you have no appreciation for something so "special" being as you treat lt like a rental Mustang.
Try and learn from others, park it in the garage and fear driving it; dont forget to buy every Zaino product known to man, too!
When you sell your investment you can then brag about "I used to have one of those" as you pop another button on your Hawaiian shirt and know deep down you had no real fun with the car but pretend to anyway.
Posted on: 2008/10/29 15:44
