208 user(s) are online (152 user(s) are browsing Forums)
(1) 2 3 »
Josh Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
I'm going to try to keep this post to the point as best I can. I'll edit with updates as I go along with new information.
Everyone please give a big thanks to tpi421vette (Jim) owner/operator of Gearhedz Race Shop in Salt Lake City, UT. Without him, this would not have been possible.
This would not be possible without donations from members of the forum. Bogus has agreed to be responsible for all the donated money. Any that is not used will be divided and returned. If you want to donate, please send your donations via paypal to abbogus@yahoo.com
There has been some question as to whether or not I'm taking the forum for a ride and simply using the members generosity for personal gain. I don't think that is the case, but I'm biased towards myself so it's impossible for me to render an unbiased opinion. However, biased as it may be, my opinion is:
I'm using the TFS heads first and then swapping to the AFR heads. I plan to leave the AFR heads on the engine. If the TFS heads make more power (or have some other desirable characteristic) it is possible that I might swap back to the TFS heads. If that ends up being the case, then I will have personally gained from the forums donations, as I normally would have just bolted on the AFR heads and sold the TFS heads without ever installing them. Should that situation arise, I'm not sure how to proceed. I suppose the best thing to do is cross that bridge when the time comes. Other than that possible scenario, I don't see how I am gaining anything by funding the test via forum member donation.
The short version:
I am testing AFR 195 Competition port cylinder heads against TFS 195 heads on my 1991 vette. I'll post dyno sheets of both, time slips of both, flow data, combustion chamber CC, intake runner CC, and over all driving impressions. That's the short version. If you aren't interested in the technical details, skip to post #2.
The long version:
Engine is a 383 with the following parts:
TPIS miniram with 1205 size ports
Eagle cast steel crank
Eagle forged rods, 6 inch, h-beam
SRP forged flat top pistons, .015 below deck
Chromoly rings
Comp Cam XFI cam P/N CCA-08-467-08 (230/236, .576/.57, 113 LSA, 56 degrees of overlap)
The rest of the engine is stock or new stock replacement parts.
I'll be swapping between 2 sets of heads for the test:
TFS aluminum 195 CC heads, P/N TFS-30400006-CNC.
The heads have bee hive springs, 10 degree locks, and titanium retainers.
The heads have been lightly ported and decked by Lloyd Elliot.
Total retail for the heads with port work and upgraded springs is $2000.
Tech data on the heads, quoted from the shop that did the testing, is as follows:
Hi Josh,
They did arrive and I already have a bunch of information for you.
First off they are 100% ported. Not just a bowl cleanup like you had alluded to. Guides are narrowed and necked downed nicely and this head had been ported from one end to the other. I might add it was done by someone who looked like they knew what they were doing and had a very neat hand (the walls were straight and the overall execution was certainly above average). The porting might not have been as obvious to you because the heads were glass-beaded when they were freshened disguising some of the finish sandroll marks that are clearly evident when you look closely.
Finished intake port volume 205 cc’s
Intake Flow
.200 @ 140
.300 @ 200
.400 @ 245
.500 @ 274
.550 @ 280
.600 @ 282
Exhaust port finished volume 76 cc’s
.200 @ 108
.300 @ 144
.400 @ 176
.500 @ 190
.600 @ 204
Combustion chamber volume is very small @ 57 cc’s (just under actually like 56.8 actually)
AFR aluminum 195 CC heads competition ports, P/N AFR-1095. Nothing has been done to the heads, they will be bolted on as they come from AFR. Total retail for these heads is $2016.
Intake:
.200 = 157
.300 = 207
.400 = 257
.500 = 287
.550 = 292
.600 = 304
Exhaust:
.200 = 127
.300 = 178
.400 = 210
.500 = 229
.600 = 236
2/11/08
I picked up the engine from the builder today. I also picked up my TFS heads from the same machinist, he did a valve job and slightly decked/skimmed the heads. I shipped one TFS head to a shop out of state for flow testing, intake runner volume, and combustion chamber CC measurements. I will have the same shop test the AFR heads.
2/18/09
I got an E-mail from the shop that is testing the heads. The information is in on the TFS heads. I copied and pasted the information up where I talk about the TFS heads. The meat and potatoes is:
Intake Flow
.200 @ 140
.300 @ 200
.400 @ 245
.500 @ 274
.550 @ 280
.600 @ 282
.200 @ 108
.300 @ 144
.400 @ 176
.500 @ 190
.600 @ 204
Combustion chamber volume is very small @ 57 cc’s.
I also got the short block installed in the car tonight. I'm using an 8 inch balancer, so some mild clearancing of the cross member was necessary. Nothing a couple light taps with a ball peen hammer didn't take care of.
3-12-09
Both TFS heads are on and torqued down.
3/25/09
Got flow information on the AFR heads. Intake is on the car, valve train is done. Hopefully, it will take it's first breath with the TFS heads this weekend.
4-13-09
Drove it around this weekend. I should have dyno numbers and track times by Sunday.
4/23/09
First round of dyno testing is done. Hopefully, I'll hit the drag strip and the dyno one more time before pulling it all apart to swap on the AFR heads.
6/16/09
Final testing is done with the TFS heads. The final numbers are:
Greatest RWHP achieved: 389
Best ET: 11.98
Best MPH: 119
Things to note: My best MPH was with a 150 Lb. passenger at a corrected elevation of ~2000 feet.
The AFR swap is under way.
8/31/09
AFR head swap is done and dyno'd. Track will happen over the labor day weekend, but the dyno results are 414 RWHP / 396 RWTQ. An increase of 25 RWHP and 23 RWTQ at the peak. The engine made more power all through the RPM band. Here is the chart, the AFR heads in red and the TFS heads in blue:
Went to Rockingham Dragway last night.
Details are:
8:57 PM - 9/5/09
60- 1.949
330- 5.256
1/8- 7.925 @ 90.27
1/4- 12.112 @ 118.13
Final ET and MPH with the AFR heads (after dialing in the tune and getting some seat time) is:
60- 1.67
1/4- 11.37 @ 122
Posted on: 2009/2/12 23:29
Randyj75 Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
MD
129 Posts
Interesting, can't wait for the results.
Randy
Posted on: 2009/2/13 1:55
1989GTA Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
61 Posts
Yes, very interesting. These are the kinds of tests I really look forward to. Thank you for doing it.
Posted on: 2009/2/13 2:12
bogus Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
I await the results!!!
Posted on: 2009/2/13 3:00
CentralCoaster Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
I like that the price tag is the same.
Don't forget pictures!
Posted on: 2009/2/13 7:18
BrianCunningham Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Nice to see someone picking up the ball on this one.
Posted on: 2009/2/13 18:12
BeachBum Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
751 Posts
Looks like a fun test !
I do not know a lot about those particular Trick Flows, but in general, I've always thought of Trick Flow as a company well focused on the street/strip generation and a good cylinder head for our applications..... should be a competitive test.
I know those TFS 195's are advertised to flow in the mid 250's before porting.... so I guess it is a matter of how much work is done to them as to exactly how competitive they are.
Good Luck !
Posted on: 2009/2/13 19:47
88BlackZ51 Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
481 Posts
Good Luck !
This gives you an idea of what the 195cc TFS heads flow as cast!
.200 lift(intake/exhaust) Trickflow-138/98
.300 lift(intake/exhaust) Trickflow-190/130
.400 lift(intake/exhaust) Trickflow-230/156
.500 lift(intake/exhaust) Trickflow-253/174
.600 lift(intake/exhaust) Trickflow-260/185
Posted on: 2009/2/14 1:05
tpi421vett Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Salt Lake City Utah
125 Posts
Thanks for the kind words Josh!
Anybody interested in some AFR's let me know.
Posted on: 2009/2/14 4:42
08 C6 LS3,3LT,Z51,A6,NPP
450ci now with AFR 235...
Josh Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Pictures of the short block and TFS heads:
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/DSCF0766.jpg[/IMG]
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/DSCF0767.jpg[/IMG]
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/DSCF0768.jpg[/IMG]
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/DSCF0770.jpg[/IMG]
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/DSCF0772.jpg[/IMG]
Posted on: 2009/2/14 6:02
MD
129 Posts
Josh, do you have a part number for the TFS heads? How old are they? I am wondering if we are comparing apples to apples.
Randy
Summit Racing
Link to the Trick Flow heads.
Posted on: 2009/2/17 2:44
I posted that information in my first post:
The TFS heads are probably 18 months old or so.
Posted on: 2009/2/17 3:02
The first post has been edited with Trick Flow tech data, I've also included the data here. In the interest of full disclosure, I've copied and pasted the E-mail from the shop that tested the heads.
Hi Josh,
First off they are 100% ported….not just a bowl cleanup like you had alluded to. Guides are narrowed and necked downed nicely and this head had been ported from one end to the other. I might add it was done by someone who looked like they knew what they were doing and had a very neat hand (the walls were straight and the overall execution was certainly above average). The porting might not have been as obvious to you because the heads were glass-beaded when they were freshened disguising some of the finish sandroll marks that are clearly evident when you look closely.
Intake Flow
.200 @ 140
.300 @ 200
.400 @ 245
.500 @ 274
.550 @ 280
.600 @ 282
.200 @ 108
.300 @ 144
.400 @ 176
.500 @ 190
.600 @ 204
Posted on: 2009/2/19 3:07
Here's some better pictures of the TFS heads the shop sent me:
[IMG]http://i652.photobucket.com/albums/uu241/joshkinzey/TFS1.jpg[/IMG]
Posted on: 2009/2/19 3:22
Short block in the car:
Posted on: 2009/2/19 5:40
481 Posts
Those heads don't flow 2 bad. This should be a very interesting test.
Posted on: 2009/2/19 18:08
It's nice that it will be a chassis dyno vs engine dyno
Some real #'s there.
Posted on: 2009/2/19 20:56
rickreeves1 Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
New Orleans
96 Posts
:goodpost:
Posted on: 2009/2/19 21:10
Since the TFS port work was more than you expected, does that changes the out-the-door price tag on them?
Posted on: 2009/2/20 0:00
751 Posts
Based upon the new information of the TF flow numbers, I'm thinking that the competition AFR 195's have an advantage of 10-20 hp due to increased flow..... but, with the small combustion chamber of the Trick Flows, compression will be up to close to a full point, which might steal some of that advantage..... but I dunno. (I assume the AFR's are the 64 cc chamber) What will your compression be with the two heads ?
No matter how you slice it, looks like a fun test....have fun with it !!
Posted on: 2009/2/20 3:10
When I bought the heads (used from someone on another forum) he sent me a receipt with them that said:
"Gasket match and chamber clean $300"
I don't really know if the porter did more than $300 worth of work or not. He charged the customer $300, without more information (hours involved, was their some kind of discount, etc...) we don't really have a choice other than to go by what is on the receipt. Maybe someone with some more knowledge of porting can look at the pictures and ball park the price that should be charged, but for right now the receipt is the only solid piece of information we have to go on.
I hate that port work might makes the test that much more insubstantial. I almost wish the TFS heads were out of the box so there were zero unknowns. Or atleast had work done to them that was absolutely quantifiable; things like the spring and retainer upgrade, new valves, etc... Stuff that has concrete price and value.
Posted on: 2009/2/20 23:15
I'm not sure what I'm going to do about compression ratio right now. If I run a .030 gasket (which is what I want to do, I'm looking for a ~.045 quench) that puts the TFS heads at ~11.8:1. I'm not comfortable with a SCR that high. If I run a thicker head gasket the quench starts to suffer pretty badly.
What I'll probably do is use a .040 gasket on the TFS heads, which puts me at ~11.5:1. I don't like the compression that high, but I don't really see another option.
Then, I'll use a .028 gasket with 65CC chambers on the AFR heads for a final compression ratio of ~10.8:1.
I think that is realistically as close as I can make the 2 heads perform on the car. Any more head gasket on the TFS combo and the quench gets out of control, any less gasket or chamber on the AFR heads starts to put me in an area that I'm not comfortable with.
It is fun, but it's beating up my Visa card pretty bad. I was hoping for a little more support from the forum, but I guess it's rough out there for everyone.
Posted on: 2009/2/20 23:25
cuisinartvette Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Cleaning up (polishing Im assuning) the chambers wont really add any power but can help reduce hot apots and the possibility of pinging.
Posted on: 2009/2/21 4:58
481 Posts
It's too bad the CR won't be closer. I guess the only thing you could do I guess is mill a little off the AFR's.
Still be a fun test.
Posted on: 2009/2/21 10:37
CFI-EFI Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Top of Utah
372 Posts
It sounds like you have the piston .015" down the hole. I wouldn't be happy with any more than a .045" quench, at the outside. How about doing some "unshrouding of the valves" in the TF heads to try to get the combustion chambers closer in size. Not only does this help the test, but it might make gathering parts a little easier too. Good luck. I wish I could help with the Visa problem, but I'm afraid I can't.
RACE ON!!!
Posted on: 2009/2/21 18:27
pr0zac Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
what cam are you using???
Posted on: 2009/2/21 19:17
The pistons are .015 below deck. I was shooting for a .040-045 quench, I don't trust the wrist pin/connecting rod enough to go much shorter than that.
I can't spend any more money on the TFS heads to open the chambers up. I would like to, but like you guys, I'm stretched pretty thin right now.
I plan to leave the AFR heads on the engine, so milling the AFR's to have a closer combustion chamber CC to the TFS really isn't an option. I'm looking for a final compression ratio of ~10.5:1, and a quench of ~.045, and that can't happen with a small chamber like the TFS heads. I'm not willing to sacrifice long term results for the comparison, especially since I'm picking up 99% of the tab. I was really hoping for some more forum support, but I guess it's tight for everyone right now.
Cam specs (and piston/deck information) was in the first post:
Chromoly rings
Posted on: 2009/2/21 19:32
751 Posts
I think despite the compression issues, it is still an interesting test..... I'm not sure, but I think in corner A: we have a 195 cc head that flows 300 cfm and will result in approxmiately 10.8-1 cr with its 64cc chamber. Whereas in corner B: we have a 205 cc head flowing 280 cfm and will result in approxmiately 11.6-1 cr with a 58 cc head.
Thus, one head is a little smaller, flows bigger but has almost a point less of a compression. It becomes a battle of flow vs compression so to speak. Will be interesting to see the effect.... I'm going to run it on my sim out of curiosity..... I don't know how accurate it will be, but its something to bench race about.
On financing for the test.....I've spent "a lot" of money over the last few months on my toy including $ 2500 to one of the manufacturers in this test.... but, I'll still throw a fifty or something into the hat if need be. Thats not a problem, but I will say, a test like this, you should be lobbying the very people who would benefit from this, which is potentially AFR or Trickflow or maybe the cylinder head porter......I'm betting the winner of a test like this could potentially see 10-20 cylinder heads sold over time based soley on the results of a test like this..... thats 10-20 thousand and would have warranted a few hundred dollar donation of some sort towards the free marketing exposure or at least you would think so.
Posted on: 2009/2/21 20:35
C4 Corvette 436 - Pure Black
Top of Utah
372 Posts
I was thinking this might be something you could do yourself at home for little to no cost. Sorry, I wasn't trying to spend your money as so many people try to do. Also, I was thinking if you could increase the size of the chambers it would be better for your combination more than good for the comparo. Either way, best of luck.
RACE ON!!!
PS. I need a GOOD set of heads and a complete induction system. I am thinking of a single plane 4 bbl manifold drilled and fitted for injectors and a 4 bbl throttle body. Does anyone on here have any surplus parts?
Posted on: 2009/2/21 23:23
I don't have any porting experience, so I'm not comfortable taking a burr to the combustion chambers. I hadn't considered that you meant I could do it myself for little to no cash; communication barrier of the forum/Internet I suppose.
If you are looking for a good set of heads, I plan to have the TFS heads for sale in a month or so. I don't have any real surplus parts, but I do have some exhaust manifold gaskets you can have for shipping. I also have an LT1 intake that is part of an aborted conversion. The distributor hole has been messed up pretty bad, but someone with more time than I have might be able to make it work. Again, catch the shipping and it's yours. I have the LT1 fuel rails with -8 AN fittings TIG welded onto them that you can have as well.
Posted on: 2009/2/22 1:42
481 Posts
Another good post by Beach. Josh, I certainly can't help you out with funding. I don't know what my 421 has cost me as of yet because I haven't added up the bills (better that way), but I am positive it's more then most would be willing to spend. Plus a bought a ZF6 to boot. I wish I could help with some funding, but I am straped!
Beach. I am looking forward to seeing what your sim spits out in regards to tq, and hp. Being that the TFS has a little bigger port, and has more compression to work with, I don't think the winner will win by a landslide.
Posted on: 2009/2/22 11:29
Top of Utah
372 Posts
The break down in communications was mine. I didn't specify, plus I ASS-U-MEd. Unshrouding the valves shouldn't take the knowledge of a skilled head porter, but if you aren't comfortable, that's that.
I am interested in all of that, but mostly the heads. I will have to go back and reread all that you've written to get a fresh handle on just what they are. I'm not sure, yet, if I am going to need heads, but keep me in mind and see what you think you need for them. Thanks,
RACE ON!!!
Posted on: 2009/2/22 19:08
This is getting interesting.
I can't wait to see the end results. Any time table?
For those of you who are still interested in donating to help Josh defer costs, my email is abbogus@yahoo.com.
I am holding all funds in my paypal acct and will forward it to Josh when the time is right.
Currently, we have ONE donator!
CentralCoaster has fronted $10.00.
If we all do that, we will get Josh a few hundred towards the dyno tests.
Let's get emailing!!! I will keep a separate thread with detailed accounting of the donations. It will be very public. Not to intimidate others into donating, but to keep this on the up and up.
Andy
Posted on: 2009/2/22 20:35
751 Posts
88black,
I haven't had a chance to run the simulator yet, but I suspect the power will be fairly close to what Wes got out of his 395 sbc..... probably a hair more HP out of Josh's motor, but a hair less torque mostly due to the Miniram.
But, not sure... will run it later in the week.
Posted on: 2009/2/23 4:45
dan0617 Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Have you checked the dynamic cr with the combos? I wouldn't be afraid of 11.8 as long as your dyamic is good. My build is together and running and has made a handful of WOT runs. It is 11.2 scr, 8.9 dcr. Running a .035 quench with stock 400 rods (with arp bolts) and crank and speed pro forged pistons in a 350 block to make a 383. This is with afr 195 eliminators. I so far have heard no detonation and no pistons bumping heads and I've turned it to 7000 rpms a couple of times trying to get the governor sorted out. Not going to do that anymore but I would not be afraid of a .035 quench and a high dcr. The tighter quench distance might very well make up for the higher scr and give you no problems at all. Just don't guess at it, find an online dynamic cr calculator and input ALL the information it needs. Take the time to get the proper information, then do some research. Again, with a good tight quench you can run dcr in the high 8's or possibly low 9's on high octane pump gas and a good combustion chamber design. Don't worry about the scr, it is what it is and it doesn't matter so long as the dcr is good.
Posted on: 2009/2/23 18:40
Top of Utah
372 Posts
That is an interesting engine parts combination. Although I have mentioned it to several people, I don't believe I've seen anyone using the short 5.565" rods, before. Those rods allow the use of more readily available (and sometimes cheaper) 350 pistons. Even the "Chevrolet Power" book specs OKs the .035" piston to head dimension. I have been thinking of pushing that, a little.
RACE ON!!!
Posted on: 2009/2/24 1:58
Here is what I think I am going to do:
.040 head gasket on the TFS heads, that puts me at ~11.5 SCR and ~8.9 DCR with a .055 quench. I think the quench is pretty wide for that much compression (both static and dynamic) but I don’t really have a choice.
I'll have the AFR heads milled to 60 CC. I’ll use a .028 gasket which will put me at 11.4 SCR and 8.85 DCR with a .043 quench.
If that sounds good to you guys, I’ll order the gaskets tomorrow and get going on putting it together.
Posted on: 2009/2/24 3:40
Salt Lake City Utah
125 Posts
I think that will work well. It will make the compression comparable, and help make good power. Keep in mind a typical L98 had a piston .025 in the hole with a .055 gasket=.080 quench. So both of these are far better than stock.
Posted on: 2009/2/24 4:21
751 Posts
To liven this dyno test up, I think we should have a poll shootout on the dyno results.... closest to guess the results, wins a guru hat or something fun like that.
Who's dyno and what type of dyno will this be on ?
Posted on: 2009/2/26 23:12
I'm presuming dynojet for repeatability sake?
Posted on: 2009/2/26 23:30
481 Posts
I have thought about this as well. I would be fun to see who is the closest.
Posted on: 2009/2/27 0:12
All the dyno testing will be on a Dynojet 224 at Mayhem Motorsports in Raleigh, NC.
I plan to have video of the dyno sessions and track time.
Posted on: 2009/2/27 2:37
Transmission is back in the car, and I got the TFS head back from the shop that flow tested it.
Hopefully, the car will take it's first breath this coming weekend.
Posted on: 2009/3/2 13:53
My help got food poisoning this weekend, so I was solo. I still got a fair amount done. The C-beam and drive shaft are in and the passenger side TFS head is on and torqued down. More reports as the week progresses.
Posted on: 2009/3/9 3:07
Posted on: 2009/3/9 16:34
Both TFS heads are on and torqued down. All the ground on the drivers side of the motor are hooked up. I'm hoping to knock out the valve train this weekend. As long as I don't have to order pushrods, I should be able to get the intake and everything on the motor this weekend.
Posted on: 2009/3/13 3:01
Calm Re: Air Flow Research (AFR) 195's VS Trick Flow Specialties (TFS) 195's - Test within
Vancouver, Canada
608 Posts
Posted on: 2009/3/13 5:23
Vancouver, Canada
608 Posts
Josh,
How you gunna be for parts and dyno costs? The donations holding up?
Posted on: 2009/3/13 5:25
The donations right now are at about $150, plus some parts here and there.
The head gaskets for the TFS heads were right at $100 shipped, so that only leaves about $50 for fluids, silicone, and dyno time.
I figure the extra $50 will cover the antifreeze, oil, filter, silicone, and maybe the intake gasktes. At this point I'm on my own for the dyno time and what ever misc. crap I'll need.
I don't think the donations are done or anything, I'm pretty sure some more people will donate as I get closer to completing the tests. Thanks for asking about it. You can see the list of people that have helped out in the donation thread Andy made:
http://www.corvette-guru.com/modules/ ... php?topic_id=7380&forum=1
Posted on: 2009/3/13 19:27
Salt Lake City Utah
125 Posts
Hey josh, can't wait to see how it turns out!
Posted on: 2009/3/14 4:49
(1) 2 3 »
