happydad | Whine in my 3:73 Diff | ||
Hi Guru's...The rear pinion seal was leaking this winter and I have yet to replace it(Lazy)..But I did take it around the block for a shake down cruise and heard a whineing noise coming from the rear...Also heard a thumping like noise(off and On,Not real Loud) coming from back there also...I guess it's time to replace the seal and refill Huh?? Although the leak did'nt seem that bad..The rear has been rebuilt and should have had the proper amount of fluid(although I did not install it)..What do you guy's think
Posted on: 2009/3/16 11:12
86 Coupe,350 bored .040 over,Eagle Internals,Scorp RR.Crane Cam,Hedman Hedders,Holley Mani,TCI Trans,3:73 Rear, Demon Carb ,Hole in the hood Scooped and Lots of leaks(Horsepower) I forget :thumbleft: |
bogus | Re: Whine in my 3:73 Diff | ||
3.73 in what? D44 or D36?
It also depends on the source of the gears... some are prone to whining. It also makes me wonder if the shop set the gears right in the first place. The on/off thumping noise makes me think LSD (diff, not narcotic). |
Posted on: 2009/3/16 13:36
happydad | Re: Whine in my 3:73 Diff | ||
D36...Will Change Seal and fill...I kinda think The SoB Did'nt Change all the U joints....
Posted on: 2009/3/16 23:27
CentralCoaster | Re: Whine in my 3:73 Diff | ||
It shouldn't be making any noise other than maybe a gear whine, low fluid or otherwise.
Posted on: 2009/3/17 4:14
It must be just the gears..Fluid is fine..Ujionts look new..Prolly not used to the gears yet..Thanks for your thoughts..I Freaked for a moment..Don't need anything else to go wrong
Posted on: 2009/3/17 10:34
anesthes | Re: Whine in my 3:73 Diff | ||
Did the pinion nut back off?
Posted on: 2009/3/17 10:36
'79 Z28. 412 CID, NP 833 transmission, 3.73 10.5" rear end. |
Thanks I'll check that
Posted on: 2009/3/17 22:54
85L98-84L83 | Re: Whine in my 3:73 Diff | ||
Screw the whining sound how is the off the line performance?
Does it peal the rubber off the tires? |
Posted on: 2009/3/18 12:21
85 vette - 3.54 gears,pulleys,160 stat,hypertech chip,K&N,no cat,B&B cat back,cut air lid,TB bypass,air pump elim pulley,air foil,Torque thrust II wheels,maaco paint job 84 vette - K&N,renegade,2 inch TB's,adustable fuel pressure to 15 psi,air pump e... |
CFI-EFI | Re: Whine in my 3:73 Diff | ||
Helpful, as usual. RACE ON!!! |
Posted on: 2009/3/18 14:28
