85L98-84L83 | Porting the stock crossfire intake manifold! | ||
I have a stock crossfire intake manifold I will be porting, where are the water jackets running? Are they on the lower part of the runners? My plan is to open up the port to match the gasket and to remove as much material on the inside of the runners. I will also shorten the runners from the inside and cut the top of the runners open about 1/2 inch from the start of the runner from the inside. I will remove the EGR hump as well. After removing the EGR hump, is there any welding needed? I will also remove the swirl viens to aid in air flow. Any other suggestions to achieve maximum power out of this stock intake manifold?
Posted on: 2009/3/25 19:58
85 vette - 3.54 gears,pulleys,160 stat,hypertech chip,K&N,no cat,B&B cat back,cut air lid,TB bypass,air pump elim pulley,air foil,Torque thrust II wheels,maaco paint job 84 vette - K&N,renegade,2 inch TB's,adustable fuel pressure to 15 psi,air pump e... |
vetteoz | Re: Porting the stock crossfire intake manifold! | ||
Buy a Renegade ,
"give you about 50hp and 33 hp at the rear wheels." http://www.smokinvette.com/corvetteforum/showthread.php?t=19966 |
Posted on: 2009/3/25 21:38
Aardwolf | Re: Porting the stock crossfire intake manifold! | ||
LOL
Posted on: 2009/3/25 21:45
CFI-EFI | Re: Porting the stock crossfire intake manifold! | ||
You forgot the 40 hp and the 16 & 22 ft.lbs. of torque. This guy doesn't know if he is afoot or on horseback. RACE ON!!! |
Posted on: 2009/3/26 18:08
85L98-84L83 | Re: Porting the stock crossfire intake manifold! | ||
I think you should just take it down a notch, this thread is about porting an intake. If you have experience in porting a crossfire intake you are welcome to share. It would be most helpful to stay on topic, you could always start a new topic if you wish.
Posted on: 2009/3/26 18:19
BrianCunningham | Re: Porting the stock crossfire intake manifold! | ||
doing a side-by-side comparison I assume?
Here ya go http://www.technovelocity.com/chevyha ... t_polish/port_polish.html Quote: With the ported manifold and a 2100 stall torque converter, I gained .35 in the 1/4 mile. I went from 15.75 to 15.4... |
Posted on: 2009/3/26 18:32
WOW!!!!, that is some serious info. In the picture the runners look shorter on one side, it just might be me.
Would there be a benefit to cut the tops of the ports back a bit, kind of taper them so the fuel can get in easier? The EGR, once removed did you notice anything with milege or codes or any problems? Why did you sand blast it? To ruff it up a bit or just to clean it? Thanks alot best write up I have ever seen. |
Posted on: 2009/3/26 18:47
Not my writeup, but I'm sure you could contact him.
Posted on: 2009/3/26 19:18
CSS996 | Re: Porting the stock crossfire intake manifold! | ||
Mega Guru
I think a civilized debate is a good thing, but making it about the person is not cool. Let's keep it friendly, like. |
Posted on: 2009/3/26 19:20
Currently "Between Vettes". |
Any other porting experts here wanting to share? If you have ported a crossfire let it rip.
Posted on: 2009/3/26 20:54
RACE ON!!! |
Posted on: 2009/3/26 21:22
Mega Guru
The moderators of the other forum can deal with it as they wish. Let's do our best not to play those games over here.
I actually do not visit other sites. Corvette-Guru is not a garbage dump for other forums. |
Posted on: 2009/3/26 21:29
bogus | Re: Porting the stock crossfire intake manifold! | ||
Agreed. Let's play nice. CFI - I have been following this and your arguments are technically sound. You are on the right track. Please, keep it civil. The argument carries more weight that way. |
Posted on: 2009/3/27 14:40
