85L98-84L83 | Boob job! | ||
How big to go? I figuire 500 to 550cc's will be good, that would make a large D maybe a small DD.
You can right them off on your taxes |
Posted on: 2009/4/5 17:18
85 vette - 3.54 gears,pulleys,160 stat,hypertech chip,K&N,no cat,B&B cat back,cut air lid,TB bypass,air pump elim pulley,air foil,Torque thrust II wheels,maaco paint job 84 vette - K&N,renegade,2 inch TB's,adustable fuel pressure to 15 psi,air pump e... |
CSS996 | Re: Boob job! | ||
Mega Guru
Was expecting a photo...
Can't help ya. Go check Andy's other site: boob-guru.com |
Posted on: 2009/4/5 18:01
Currently "Between Vettes". |
redvette6spd | Re: Boob job! | ||
Hmm well let's see
Posted on: 2009/4/5 18:23
Durango_Boy | Re: Boob job! | ||
Who is the augmentation for? Pics? Body type should dictate the size of the breast. Too large on a small frame will look awkward. Too small on a large frame would be a waste of money. In perspective, Audrina Patridge has around a 500cc as an example. |
Posted on: 2009/4/5 18:34
BrianCunningham | Re: Boob job! | ||
I'm more of a purist, I like mother nature.
Can doc can make them look natural? |
Posted on: 2009/4/6 2:24
85L98-84L83 | Re: Boob job! | ||
They will probably look like the picture of old sneezy you have there. |
Posted on: 2009/4/6 11:59
xccter | Re: Boob job! | ||
Posted on: 2009/4/6 13:10
ยด71 350/270 L48 Coupe Numbers Matching Ontario Orange 4 spd, Mid-year side pipes, deluxe black leather, ac, ps, pb, pw, tilt/tele steering wheel. 93k miles. Original rotors still riveted to the hubs! NCRS #48337 |
TommyT-Bone | Re: Boob job! | ||
Ya, I'd look at a few thousand first so you can get a better idea. |
Posted on: 2009/4/6 13:40
