292 user(s) are online (245 user(s) are browsing Forums)
guitarbare Need This Part Can anyone help
2 Posts
[align=center]
This is for a 1990 ZR1 with sports seats. Next to my left leg is a bolster
part of the seat that holds two rocker switches. after all the getting in and out of this car
The Plastic part that hold those switches finally broke since I have to go over it each time I get in or out. What is this part called or better yet part number and where can I get a new one?
Larry 1990 ZR1 1996 Grand Sport and 1999 C5 :silent:
Posted on: 2007/11/26 5:42
bogus RE:Need This Part Can anyone help
I think I can help you. I have the switches from my OEM 92 seats.
Posted on: 2007/11/26 5:53
guitarbare I found it!!!!!
2 Posts
It's called a Bezel dealer says it's discontinued. Found the part ranging in price from $40 down to 11.99 from Eklers :thumbleft:
Thanks for help
Larry
Posted on: 2007/11/28 14:12
vett40 RE:Need This Part Can anyone help
mass
2 Posts
newbe here just a suggestion i have a 93 ruby i rebult the seats and when i put them back i switch them by mistake i had put the driver side on the passage side and the passage side on the driver so you have to side over the switches getting in and out them i notice pictures of interior and saw that the switches where on the inside i switch them back and like it alot better hope this helps
Posted on: 2007/12/13 23:51
kentucky_vetter switches
somerset, ky
154 Posts
i thought they were all on the inside edge of the seat ?
Posted on: 2007/12/20 2:49
