85L98-84L83 | Renegade 1/4 mile times. | ||
I finally have some 1/4 mile times for my renegade equiped crossfire.
My first run with alot of wheel spin netted a 14.87, this run was done letting the auto trans self shift. It shifted to soon. The second run I shifted the auto trans myself and had alot of wheel spin and when I shifted into second it spun again and I got a 14.46. The next run I eased the throttle on with little wheel spin and got a 14.43. But with the less throttle it bogged a little off the line. Next pass I gave it more throttle and had alot of wheel spin and got a 14.39. Pretty good for a stock bottem end with just a K&N, renegade, 2" TB's, shift kit, and a random cat, underdrive pulleys, hypertech chip 180 stat, walker rear y pipe, muffler eliminators, fuel pressure set at 15 psi, timing set at 10. The crossfire has 65,000 miles on it. 14.87 elevation 2100'= 14.50 14.46 elevation 2100'= 14.10 14.43 elevation 2100'= 14.07 14.39 elevation 2100'= 14.04 |
Posted on: 2010/12/31 16:11
85 vette - 3.54 gears,pulleys,160 stat,hypertech chip,K&N,no cat,B&B cat back,cut air lid,TB bypass,air pump elim pulley,air foil,Torque thrust II wheels,maaco paint job 84 vette - K&N,renegade,2 inch TB's,adustable fuel pressure to 15 psi,air pump e... |
bogus | Re: Renegade 1/4 mile times. | ||
What did you get BEFORE the Renegade installation, meaning, you still had the stock intake on there.
Posted on: 2010/12/31 17:14
CentralCoaster | Re: Renegade 1/4 mile times. | ||
And show your 60' and mph as well. The ET is meaningless without them.
Posted on: 2010/12/31 17:21
BeachBum | Re: Renegade 1/4 mile times. | ||
Looks like pretty good et's out of a crossfire ! Congrats !
I do agree with Central Coaster on the 60 ft and trap speeds..... they help tell the story to the reader. btw, what is a Renegade ? |
Posted on: 2010/12/31 23:01
863 cubic inches of C4 & C6 muscle C6 Corvette Z06 - Lemans Metallic Blue C4 Corvette 436 - Pure Black http://www.cardomain.com/ride/3933547 ... chevrolet-corvette/page-1 |
vetteoz | Re: Renegade 1/4 mile times. | ||
The greatest automotive product since Otto invented the 4 stroke petrol engine according to "some" especially the OP ben73 on CF got impressive results with it over his X Ram equipped 383 but he has 5 years of comparison data to back up his results http://forums.corvetteforum.com/1575335208-post29.html |
Posted on: 2010/12/31 23:19
cuisinartvette | Re: Renegade 1/4 mile times. | ||
Similar elevation to LACR Id say it was running pretty strong.
Really need 60ft and mph as others say to make a better judgement call. Sticky tires could net you a much better time sure you know. |
Posted on: 2011/1/1 2:04
I would agree, those ET's do look good. But the 60' and trap will help determine where the manifold is helping.
Posted on: 2011/1/1 2:23
pr0zac | Re: Renegade 1/4 mile times. | ||
Hahahahahahahahahahahahahahahahahahahahahahahahahahahahahahaha.. Gasp.. Hahahahahahahahahahahahahahahahahahaahahahahahahahahaahahaha.
Money well spent. |
Posted on: 2011/1/2 3:03
Josh | Re: Renegade 1/4 mile times. | ||
Didn't CFI-EFI go into the 13's with the stock set up?
Posted on: 2011/1/2 4:39
CFI's, IIRC, was a stock intake, but gaulled out... and with big block throttle bodies... and some aluminum heads. I think, in short, he actually built the engine... not just a bunch of bolt ons, hoping for a miracle.
Posted on: 2011/1/2 6:29
