301 user(s) are online (253 user(s) are browsing Forums)
JrRifleCoach Something to consider at 200 MPH
1524 Posts
By now most of you have seen or read about the first C7 to break 200MPH.
You can view the vid at the "other" site.
Amazingly the Texas DPS sanctioned the run and apparently under the guise of testing the new tollway's automatic authorization system. When I first saw the news and article I was like "meh" a C7 topping out at two-hunert on the bottle, whats the big deal?
Then I watched the video.
OMG! that was a feat! Not only did the driver go through 100 MPH holding onto the steering wheel with just one pinky finger...
He broke out @ 200 with one hand and a pinky finger!
Truly an impressive display of driver ignorance & stupidity.
Posted on: 2013/12/20 1:25
bogus Re: Something to consider at 200 MPH
or the quality of the car...
but you are right, hold that damned wheel. At that speed, any shift in the pavement, and he is heading towards Oklahoma...
Posted on: 2013/12/20 1:40
BillH Re: Something to consider at 200 MPH
Agreed.
But also, 100 mph is like nothing, not very fast.
Try running these speeds in a race car with 1/8th inch of toe out.
Posted on: 2013/12/20 2:00
BrianCunningham Re: Something to consider at 200 MPH
Knowing the builder, he didn't own the car
do a search...
Posted on: 2013/12/20 16:30
