194 user(s) are online (138 user(s) are browsing Forums)
RockAuto.com has added part kits to our catalog!
Guest_
Some of the part kits available through RockAuto.com include:
*KYB Shock Absorber & Mount Kits and Strut & Mount Kits in the “Suspension” category
*Power Stop Rotor & Brake Pad Kits in the “Brake/Wheel Hub” category
*Four Seasons A/C Compressor & Component Kits in the “Heat & Air Conditioning” category
*Bundle (Standard Motor Products) Tune-Up Kits in the “Ignition” category
There are many advantages of buying a kit rather than individual parts:
*Kits conveniently include all of the components you need allowing you to order what you need with a single click
*Kit components are designed to work together to meet or exceed OE performance
*Kits include all of the parts that are needed to perform a more complete service, ensuring greater success now and preventing problems in the future that could have been avoided
Check RockAuto.com to see if there is a kit available to complete your next project!
Posted on: 2014/6/27 13:37
