CentralCoaster | Body drop possible on C4? (engine out the bottom) | ||
Some of these photos make me curious, if it's possible to separate the unibody from the engine and suspension with a 2 post lift, leaving the engine in place. Has anyone heard of this being done? Or would it require cutting up the frame somewhere?
Posted on: 2015/6/4 1:03
bogus | Re: Body drop possible on C4? (engine out the bottom) | ||
nope... very doable..
remove the bolts at the cradle, remove the bolts at the batwing, remove the dogbones, drop the exhaust. lift and separate. |
Posted on: 2015/6/4 1:42
CentralCoaster | Re: Body drop possible on C4? (engine out the bottom) | ||
The exhaust could stay too.
Posted on: 2015/6/4 3:36
at least drop the muffler hangers...
Posted on: 2015/6/4 21:04
BrianCunningham | Re: Body drop possible on C4? (engine out the bottom) | ||
Upper shock mount part of the frame or cradle?
Looks like the upper mount is part of the cradle in the photo |
Posted on: 2015/6/4 22:55
rear upper shock mounts would have to come off.
Posted on: 2015/6/4 23:47
Take another look at the photo of the "cradle"
They cut a section of the frame out. The _actual_ engine cradle can drop out, but not with the upper suspension assembled. |
Posted on: 2015/6/5 11:56
good point. Yes, upper shock mount would have to come out.
Posted on: 2015/6/5 18:09
