511 user(s) are online (224 user(s) are browsing Forums)
383tpimachine Tire height
Corpus Christi
976 Posts
Was wondering how tall of tires people have fit on their C$ without issue.
26-26.5 are no issue but what about 28in?
Thanks for the help/pics.
Posted on: 2015/10/11 21:58
1970 El Camino-Awaiting LSX
CentralCoaster Re: Tire height
Not a chance. That adds an inch all the way around. My 26s almost rub at full compression. Obviously narrower fits easier, but 28" is just way way out there. You building a donk?
Posted on: 2015/10/13 3:29
rklessdriver Re: Tire height
I don't know about the front. I run a 26X4.4 on the front.
I do run a 28X10.5 slick and fits fine but that's about the limit without some trimming to the inner fender on the rear.
I still had to trim the inner rear of the inner fender a little because of tire growth in the burn out box and at the big end on 1/4 mile tracks.
[URL=http://s50.photobucket.com/user/rklessdriver/media/1984%20Corvette/Cherokee017.jpg.html]Resized Image[/URL]
[URL=http://s50.photobucket.com/user/rklessdriver/media/20130425_181601_zps362da0d9.jpg.html]Resized Image[/URL]
[URL=http://s50.photobucket.com/user/rklessdriver/media/CorvetteMasonDixion_zps4291e44f.jpg.html]Resized Image[/URL]
Posted on: 2015/10/13 12:29
bogus Re: Tire height
20883 Posts
In general, the C4 was never designed with these massive 19" and greater rims.
In fact, they look kinda silly, in my opinion.
I would recommend an 18" rim, with a width and aspect ratio to keep it as close as possible to the 17" stock height. If for no other reason than the keep the ABS computer from freaking out!
Posted on: 2015/10/14 0:55
