312 user(s) are online (251 user(s) are browsing Forums)
Kckckc Torque Thrust Wheels for 1987 Coupe
Las Vegas
2 Posts
Hi,I am tired of looking at the factory rims on my red 87 coupe (32,000 orig miles) and like the look of the Torque Thrust. The anthrecite should look good against the red. I want to run 275/40/17 front and 315/35/17 back. What width/backspacing do I need? Will I need to run spacers since the early c4 requires less positive offset than the later c4. Thanks!!!
Posted on: 2018/1/2 15:56
hcbph Re: Torque Thrust Wheels for 1987 Coupe
269 Posts
Try this site out: https://www.wheel-size.com/calc/?wheel ... &wcl=30mm&scl=50mm&sr=0mm
I used it when switching tire and rim sizes on my 86 and it was very helpful. You do need to do some careful measuring but it was worth it.
Posted on: 2018/1/6 1:38
bogus Re: Torque Thrust Wheels for 1987 Coupe
Also check Tirerack.com.
They sell those rims.
The 315's are hard to come by... only a couple of companies make them.
Posted on: 2018/1/7 21:23
