286 user(s) are online (260 user(s) are browsing Forums)
cor123 CORVETTE RACING AT LE MANS: “Winning is the Goal”
935 Posts
Two Corvette C8.Rs entered in GTE Pro category in search of ninth class win
· Return to June date, open fan events among highlights of French classic
· Milner, Tandy welcome back Sims in WEC championship chase
· Garcia, Taylor, Catsburg back in GTE-spec Corvette
DETROIT (May 31, 2022) – The Corvette Racing band is back together for the
first time in three months with the team channeling all its efforts into
another shot at a class victory at this year’s 24 Hours of Le Mans.
Two of the familiar yellow Corvettes are part of a seven-car entry in the
GTE Pro category for factory and factory-supported teams. This will be the
second time at Le Mans for the mid-engine Chevrolet Corvette C8.R after a
runner-up class finish in its debut last August. The program is going for
its ninth class victory at the French endurance classic.
This year’s race is back in its traditional June spot with the race set for
June 11-12. The biggest change from last year’s event is that all
public-facing events are back including scrutineering in downtown Le Mans,
pit walks and autograph sessions and the Friday drivers’ parade.
Before practice and qualifying gets under way, though, first comes eight
hours of track time Sunday during the annual Le Mans Test Day. It’s the one
opportunity for the 62 cars entered in the race to get much-needed track
time ahead of Wednesday’s first practice and qualifying sessions. Time is
critical given the unique nature of the circuit – 8.47 miles of asphalt
featuring a mix of permanent racetrack and public roads through the French
countryside.
The Corvette Racing lineup in each of the two C8.Rs remains the same as a
year ago. Antonio Garcia, Jordan Taylor and Nicky Catsburg – primarily
competing in the IMSA WeatherTech SportsCar Championship – will team in the
No. 63 Mobil 1/SiriusXM Corvette and hope to improve on their second-place
showing from a year ago. Already, the trio has a blue-riband victory
together in at the Mobil 1 Twelve Hours of Sebring in a GT Daytona (GTD) PRO
version of the C8.R.
On the other side of the garage is the No. 64 Mobil 1/SiriusXM C8.R of Tommy
Milner, Nick Tandy and Alexander Sims. Their entry is a full-time one in the
FIA World Endurance Championship – a first for Corvette Racing. It’s already
been a successful run for Milner and Tandy with a runner-up finish in the
Sebring 1,000 Miles.
The duo stand third in the GTE Drivers World Championship with Le Mans being
a double-points race. That makes it even more important for the No. 64
Corvette to show well at Le Mans… and keep the other manufacturers off the
top step of the podium as well.
The plan of having a Corvette full-time in WEC was focused around optimizing
the team’s chances at Le Mans. Corvette Racing’s last win at Le Mans came in
2015, although the team has been agonizingly close to getting its ninth win
there since with a second- and third-place showing in the years since.
The WEC Corvette has given the entire Corvette Racing team much-needed
insight and data on a wide variety of items that will be key at Le Mans.
Things like pit stop procedures, tire selection and performance, and racing
rules in a variety of scenarios make this the most prepared that Corvette
Racing has been for Le Mans in what will be its 22nd appearance in the race.
One of the most key benefits is that the No. 64 Corvette can focus more on
race setup and development on the Test Day while the three No. 63 drivers
can get used to the GTE version of the Corvette, which features more power,
no ABS system and Michelin tires specifically designed for the C8.R. In
IMSA, the GTD PRO Corvette runs on a common Michelin tire that is available
to all teams.
Corvette Racing will contest the 24 Hours of Le Mans on June 11-12 with the
green flag set for 4 p.m. CET and 10 a.m. ET. MotorTrend TV will air the
race live with the MotorTrend App adding coverage of official practices and
qualifying on June 8-9. Live audio coverage will be available from Radio Le
Mans starting with Sunday’s Test Day.
ANTONIO GARCIA, NO. 63 MOBIL 1/SiriusXM CHEVROLET CORVETTE C8.R: “Le Mans
shouldn’t be too different this year. It would be way different if we were
running the GTD PRO spec. We are going back to our regular GTE setup in the
C8.R, and I’m looking forward to that. Part of it won’t be ideal as Jordan,
Nicky and myself will need to readapt to that car a little bit. Having the
64 car in the WEC will help the whole team, though. We will need to get up
to speed at the start and maybe the 64 car will start some development early
on. We’ve done this race so many times and have raced the GTE spec so many
years that it won’t take much to get on the pace. To be honest, it is more
difficult to drive the IMSA car compared to what we have driven for the last
15 years!
“It’s been too long since I have won Le Mans. We’ve been on the podium
several times and could have won all those. That also tells you that you’re
one of the most angry people because coming in P2 or P3 is not ideal,
especially if you have a chance to win. In these races, only one car can
win. If you give it everything you had and you didn’t win, then someone did
it just a tiny bit better than you. Last year, I think we had everything
lined up. The pace was great but we didn’t have enough to gain those 20, 30
and 40 seconds to get ahead. It seems like very little over a race distance
but we know that’s how Le Mans works. Every second you lose is very
difficult and gaining that back in GTE Pro is a tough task. We need to be
the ones leading and let the rest catch us. I think that is what works best
at Le Mans.”
JORDAN TAYLOR, NO. 63 MOBIL 1/SiriusXM CHEVROLET CORVETTE C8.R: “I got to do
some tire testing with Nick (Tandy) a couple of days after Sebring in the
GTE car. But I still think it’s going to be a big adjustment for us going
back to that, especially with it being such a tight schedule on the race
week. There is such limited time to get three guys through the car with such
a long lap and adding in the car development we want to do. Hopefully we can
hit the ground running and get comfortable right off the bat to get into
development. So it will be a little bit more of a challenge but having the
64 guys over there all year in WEC takes away some development time, so
hopefully that will help us when we get there.
“It’s frustrating to look back at last year to know we did nothing majorly
wrong, didn’t make any mistakes and still came up short. That part is
frustrating but I think we can rely on the fact that we did a perfect race.
We can have that confidence going back this time. We’ve developed the car
further than where it was last year for the first time with the C8.R. We did
miss a lot of practice on the 63 side throughout the beginning of the week
so I think we were behind the eight-ball a little bit compared to the other
car once the race started. So we maybe were missing a little bit of
performance on our own. But going into this year with what we learned last
year and the confidence of a good race we had, we know we are going back
with a stronger car and good position.”
NICKY CATSBURG, NO. 63 MOBIL 1/SiriusXM CHEVROLET CORVETTE C8.R: “Having now
done Le Mans with Corvette Racing, I can go into the weekend a little more
relaxed. I know how the team operates and even the most basic things – where
I stay and where I sleep, how processes work. From that point of view, I
will be a little more relaxed going into the event. In terms of race prep
and how we are going to execute, I don’t think there is anything different
than the previous year other than the fact that everyone has a little more
experience with the C8.R at Le Mans and in the WEC. I feel we should be
pretty well prepared.
“There is some mojo from our win at Sebring. The car felt really good last
year at Le Mans. Maybe Ferrari had a little bit of the upper hand, but I
feel like this year we should be in a better position. The only downside is
the 63 car guys have driven the car less in GTE spec. The last time I drove
a car without ABS was Petit Le Mans in the Corvette. That’s a bit of a
handicap but we’re all more than capable to make that adjustment and be
ready for it. I’ve always been going back and forth between GTE and GT3
whenever I would come race in the States last year. You’d always have to
take some time to adjust to the car. Really the biggest difference is the
ABS, and I honestly prefer a car without ABS. We’re all in the same boat and
we can all do this, for sure. Le Mans is one of my favorite events of the
year. The track obviously is fantastic and abnormal in that way. I really,
really can’t wait!”
TOMMY MILNER, NO. 64 MOBIL 1/SiriusXM CHEVROLET CORVETTE C8.R: “Winning
obviously is the goal. I feel like every time we’ve been to Le Mans, we’ve
done all our due diligence beforehand in testing to show up as competitive
as we can be. Having some experience this year in WEC and data running on
this tire will be helpful for the entire team. From that perspective, this
will prove to be very helpful. We’re going to be as prepared for Le Mans as
we can be. We saw last year that the car already was fast and competitive.
Hopefully with the potential for more data for the ACO and FIA to compare
our cars, the balance is as good as it can be for a good GTE Pro race for 24
hours. Based on the pace we’ve show in the WEC and last year at Le Mans, I
think we have a great Corvette.
“Running WEC doesn’t change anything for me in terms of preparation. No
matter what, we finish the race and we finish as strongly as we can. It hasn’t
been in the past where if we can’t win then we park it. It’s not our mantra
at Corvette Racing. We race hard to the end no matter what our position is.
Now that we have some concerns for points in the full WEC championship, we’ll
race with that in mind. But it doesn’t change the fact that winning Le Mans
would be the crown jewel for this season. This is how we’ve always raced and
it won’t change. It just means that the points at the end of the weekend
will mean a little bit more.”
NICK TANDY, NO. 64 MOBIL 1/SiriusXM CHEVROLET CORVETTE C8.R: “Le Mans is Le
Mans. It’s always been its own event. Now it’s a part of our championship
and a double-points one at that. So it takes on extra significance now for
us this year, at least on the 64 side. One of the reasons we entered the WEC
is that it gives us more preparation, information and experience of the
series’ rules and regulations. It’s things like pit stop sequences,
maximizing strategy information and bits and pieces that are different from
series to series. We have more information about what we can do better going
into Le Mans. We’re coming into Le Mans with the best level of preparation
that Corvette Racing has ever had.
“Certainly from the crew and engineering side, everyone on our side is ready
to go with what we’ve been working on for the last six months effectively.
When the track goes green for the Test Day, we’ll be ready to go and crack
on with our performance work. When we’ve been there before as a single
event, it does take a little bit of time to get into the differences – where
the guys are running the car being on the pit wall, people worried about
making regulation errors in the pitlane or things like this that we aren’t
used to. From that point of view, this is one of the key points of running
the full championship. The more experience you have, the better it is. Past
that, everyone on the 63 side have all been here and done this many times.
It’ll be the first time that we’ll run the low-drag aero kit so the car will
be a little different than what we were used to at Spa. The other good thing
is that we have last year’s experience and data to look back on. We’re not
coming into this with a brand new car.”
ALEXANDER SIMS, NO. 64 MOBIL 1/SiriusXM CHEVROLET CORVETTE C8.R: “The fact
that this will be a bit more familiar to me will be a nice thing. The
biggest factor me is the length of time that it’s been since I was last in
the car at Petit Le Mans. That likely will be the biggest challenge to get
on top off… just to get back in the swing of things. I’m fortunate that I am
doing some GT racing at the Nürburgring this year, so I’ll have driven a GT
car but not the Corvette. That’s really the main thing – getting back into
the swing of driving the C8.R. To be fair, the last time at Le Mans and by
the time the race came around, I felt fully in tune and that’s the aim again
this year.
“There is plenty of track time available but I need to make sure I do my
homework and work very hard to get up to the required level that I expect
from myself and that the team deserves from me. That will be the main point
of focus for me early in the week. I go back there with reference points
from the car from last year in terms of my driving. I kind of know what to
expect in terms of how the car should feel, driving lines and all of those
things that I don’t have to learn again. It’s a slightly more manageable
task than last year.”
https://cimg8.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/732x975/2tracksideracingnews_egnyte_com_copy_e21e0188daa74d88ea0fad20fe32f71baaa7fd27.jpg
Posted on: 2022/5/31 20:51
bogus Re: CORVETTE RACING AT LE MANS: “Winning is the Goal”
The race, officially under the banner of the WEC, should be on MotorTrend TV for much of the race.
I hope.
Internet is an option, but the best options are accessed via a VPN, where you can mask your IP and make them think you are in Europe.
Posted on: 2022/6/1 21:43
