225 user(s) are online (199 user(s) are browsing Forums)
GRIS 1 FEBRUARY 2023 IMBOLIC
OKLAHOMA
7625 Posts
THE END OF WINTER FOR THE ANCIENT CELTS; THE REST OF US WILL BE STUCK WITH IT A WHILE :-(
Posted on: 2023/2/1 14:16
GRIS Re: 1 FEBRUARY 2023 IMBOLIC
OKLAHOMA
7625 Posts
24, OVERCAST, AND BREEZY IN THE NATIONS THIS MORNING. WE MAY GET ABOVE FREEZING TODAY, A SCORCHING 34.
FIXING TO GO OVER TO TAHLEQUAH FOR A HAIRCUT, GOING TO WORK CROWD SHOULD BE THERE BY NOW. ROAD CONDITIONS NOT AS SCARY AS INEPT DRIVERS---OUR DRIVEWAY MAY BE THE WORSE SHAPE OF ALL.
I'LL TAKE DW'S LITTLE BLUE CAR, IT HAS 4WD.
Posted on: 2023/2/1 15:38
Matatk Re: 1 FEBRUARY 2023 IMBOLIC
22802 Posts
Good Morning CGs!
Wow, February already? Hard to believe.
Took two of the Camaro rims off and brought them to discount tire yesterday to get remounted and balanced to fix a bead leak. One of the problems with older chrome rims is they will flake or corrode and it doesn't seal correctly. So the guy redid the one and said it might still leak a little but it's better. Then he showed me a nice crack in the second rim. Wonderful. These rims are pretty rare and hard to find so luckily I was able to take it to a local guy that does alloy rim welding and he said he could fix it no problem. He just called me to say it's ready. So at least I lucked out on that. Normal price is $160 but he's a friend of a friend so he's doing it for half. All these cars take is time money and patience right?
Hope everyone has a great day!
Posted on: 2023/2/1 16:08
vetteblondie Re: 1 FEBRUARY 2023 IMBOLIC
Jonesboro, AR
4641 Posts
Good morning and blessed Imbolic to all, get those fires lit.
25 when we headed out the door this morning, roads slicker than slug snot but we made it fine. Saw 2 in the ditches on the way. Can't seem to get warm in here but think I finally have the bedroom Nest thermostat figured out. Heat would come on when you walked by it, then when it kicked off it would get cold. Yesterday I saw it at 63. I have a puck that reads the actual temperature since it's warmer usually at the thermostat, and I shut off "auto scheduling". Turns out there's a "eco" setting I didn't know about and it allowed the heat to drop to 63. I bumped that up to 68 so finally stayed warm all night. Don't figure our add-on is insulated correctly anyway. Working on getting the bus ready for print, having to mess with some color to make stuff match. I used what they sent but it's jacked and really uneditable the way I got it, so rigging it is. Y'all keep warm, stay safe and have a good one.
Posted on: 2023/2/1 16:12
�Ugol's Law
TommyT-Bone Re: 1 FEBRUARY 2023 IMBOLIC
33758 Posts
I'm happy for you that you were able to get a good rim job, Matt. Just got back from the oral surgeon. They called me yesterday and asked if I was available to do it today. They put in the post that will hold my permanent implant. It takes 4 months for it to heal and be ready for the new crown. That tooth is an expensive little sucker. The slider I have now is a pain so a permanent crown in the long run be worth the expense. I'm in a little pain so I don't think I'll be getting much done today. Just find some ways to keep distracted.
Posted on: 2023/2/1 17:32
Ultraman Re: 1 FEBRUARY 2023 IMBOLIC
14728 Posts
..just checking in..... busy busy.....
Posted on: 2023/2/2 0:03
OKLAHOMA
7625 Posts
MADE IT OVER TO TAHLEQUAH FOR MY HAIRCUT BUT THE BARBERESS DIDN'T. PICKED UP SOME DINOSAUR BONES FOR THE WONDERDOG AND CAME HOME.
THE LITTLE BLUE CAR DID GREAT, NEVER HAD TO PUT IT IN 4-WHEEL. HIGHWAY WAS NOT BAD UNLESS YOU HAD TO PASS, CITY STREETS JUST PASSABLE. THIS WAS MY FIRST GO WITH FRONT WHEEL DRIVE ON SLICKUM. DIFFERENT :-)
Posted on: 2023/2/2 1:01
