173 user(s) are online (73 user(s) are browsing Forums)
Anonymous GL-4 Gear Oil in my Differential!!
35 Posts
I got the fluids I needed from my chevy dealership to change my differential fluid. 2 bottle of additive and then the gear oil they sold me. Stupid me, I asked for "differential fluid for a '91 corvette" and now after driving it for 30 miles, I notice the bottle said it was GL-4.
How much damage did I do? Do you think I will be fine if I don't drive it anymore until I get it replaced with GL-5 oil?
Thanks
Posted on: 2006/8/7 2:59
brut RE:GL-4 Gear Oil in my Differential!!
New Albany, IN
1308 Posts
I am no gear expert but I am pretty sure you will be ok if you park it now until you replace it with what is recommended by GM. Those gears are pretty tough and running GL-4 for that short time period shouldn't have done any damage at all.
BTW, welcome to the guru!
Posted on: 2006/8/7 11:17
CasetheCorvetteman RE:GL-4 Gear Oil in my Differential!!
It will be ok, just dont flog it til you get it changed out again. It wont hurt anything.
Posted on: 2006/8/7 12:36
