84C47755 | 1984 AC part | ||
Does anyone know what part # 10007057 on the AC does? I think this is a switch on the back of the compressor. Mine is broken, and I am trying to figure out if I can replace it. Any help would be greatly appreciated.
Posted on: 2008/3/17 13:13
pappyfreebird | Re: 1984 AC part | ||
no good on the no. but ony switch on my 84 in back of comp. is the fan switch...and when mine went bad it made fan run all times with key on
Posted on: 2008/3/17 17:50
MAXXWRENCH | Re: 1984 AC part | ||
THAT IS A HIGH PRESSUR CUTOUT SWITCH SO YOUR COMPRESSOR DOES NOT OVERCHARGE SYSTEM...
Posted on: 2008/3/17 19:43
ONE SHOT, ONE KILL, I WIN |
84C47755 | Re: 1984 AC part | ||
Thanks. At this point, all that is on the compressor itself is a metal cylindrical part with a little lip. The plastic bit that appear to be part of that metal part is broken off. The other half of the plastic part (that is attached to the wiring harness) is intact. Can I remove that metal part and get a new one?
Posted on: 2008/3/18 0:00
